ever seen a boat blow an engine that threw parts through the hull of the boat?
Can't recall a hull breaching from engine internals, seen a few I/b gearboxes come out the bottom.
Best breaching that I won't forget: we had a 16l standby generator mounted on a platform outside a grocery store. She chucked a rod, went thru the exterior wall, clear into the store. Left a nice mark on the linoleum floor.
"Cleanup on aisle 12".
Didn't the Old "Drambuie on Ice" boat put a hole in the bottom when one of his motors blew up? I know it partially sank but can't remember if it was from hitting something or engine parts going through the bottom... Jim
i think a water hose came off and the boat did not have a valve .
If I'm not mistaken it happened at the NYC Poker Run this year. It was a totally re-done Aronow..... sweet boat..... Heard they blew a motor and something went through hull.... They got towed back in and the bilge pump kept up........
You are correct on that one.. But it was a flywheel that let lose..
