Wiring engine pictures
SORE MEMBER
1 Post
Yes you can ground to block, on trucks they run the ground back to the batteries.
I have all the same sensors, high oil temp, high water temp, low oil pressure(set at 30psi), low fuel pressure 5psi, low ps fluid + the usual merc stuff.
They all trigger the merc alarm which also lights a pro-light. cant hear the alarm at speed can certainly see that bright ass light. Would use led now if I redo.
Also have the fume detector and auto blower
Found the NOS switches and sensors to be the best and adjustable to the numbers
You did way better than average for a first attempt.
SORE MEMBER
1 Post
You can ground it to the block as long as you have a clean spot that free of paint, rust, etc.
The wiring is looking good brother.
Here are a few of mine.
We make the electronics plates in house out of aluminum, carbon fiber, whatever.. That is the key to having neat wiring. You must have a good place that is centrally located to mount everything. I also find it helpful to sketch out a schematic of all of the wiring first, so that I don't forget everything. There is nothing worse than strapping everything up nice and neat and realizing that you forgot a wire.
![Thumbs up](/forums/images/icons/icon14.gif)
Eddie, I was checking out your Facebook page pics. before I got started , good inspiration and ideas fo sho!!
Some amazing work you guys do.
Thanks Dan. That's why we put the pics up there.....so guys can hopefully get some ideas from them to use in their own application.
