4000 HP Shoell DDC 85' bow rider?
http://www.yachtworld.com/boats/2004...s#.VEO1XfnF_1g
Four C-18 CATS = 4,000 HP + 4,000 Gals = Great Performance & Great Range - See "Performance Stats" - in DESCRIPTION Section.
The Patented "Delta-Conic" Hull is efficient and provides a great ride in all sea-states...
Cruising comfortably at 32 knots, with a top speed of 45 knots, plus a 4,000 fuel capacity, gives the owner more range & comfort than most of the comparable 80-foot "Offshore" hulls on the market today.
With 360-degree visibility at the Helm, and four (4) C-18 CAT'S - For a total of over 4,000 HP- with ARNESON Surface Drives, you are really the Master of your Cruising Destiny.
Forum Regulator
That's the one and only 85' Active Thunder.
Just kidding.
Harry has built a handful of one-off boats over the years. He has a 47' or so that is also pretty awesome. Do a little digging, and you might find some similar lines to another DDC boat he designed.
Just kidding.
Paint "Baywatch" on the side in red and sell it to Hasselhoff....
Also, they forgot the "c" in Schoell. I was all set to submit an offer, but I rarely buy 7mm dollar yachts from brokers that CAN'T SPELL.
Neno the mind boggler
I dont think i have ever seen a boat that screamed "DOCK PARTY!!!" more then that
08 OPA High Points Champion
The yacht is here on the Chesapeake Bay....drejustice keeps his new Active Thunder at his Marina, so there are 2 there Brian!!!
http://www.pleasurecovemarina.com
For almost 7mm I could probably buy ever AT Pat has built! ![Big Grin](/forums/images/smilies/biggrin.gif)
This is a goofy boat and not a single engine room pic!
Also, just noticed rear deck.
Pretty dam cool to party on, or maybe put a couple jet skis on. But also a good way for those surface drives to chop your nads off if you are back there while under way and lose footing.
No rails, cables, nothing! !
Forum Regulator
I think a coat of dark blue or charcoal metallic paint would do wonders for it; replacing all of the Baywatch yellow.
