Oil drain hose
I don't have a trailer. I keep the boat on a boat lift. I cannot change the oil through the transom. I will see if it will pull through the dipstick tube and if not then it's down to the little 1/4 OD plastic hose
Ginger or Mary Ann?
Both of my 502's will leave a qt of oil in the pan when using the dipstick tube as the means to remove the oil as that tube doesn't go all the way to the pans bottom. I'll suck as much out with the tube and garden hose fitting, then insert the 1/4" tube till I hear it hit bottom to get that last qt out.
If your changing the oil at regular intervals 1/2-1 qt left over is no big deal. Just suck through the dipstick tube and call it a day .
I've been part of a Mercedes Benz forum for years and everyone always talks about not getting the last drop out using the dipstick tube. However, the truth is the dipstick tube almost touches the bottom of the oil pan and the little that is left over doesn't amount to a pitcher of warm spit. You are absolutely correct - as long as you change your oil at regular intervals and use a good grade/brand (and I even doubt if there is much difference in brands) you shouldn't have any oil related issues.
Also, if you look at where the drain plug is on most oil pans-- most are a little above the bottom of the pan -- you need to put the threads in somewhere. That little bit of residual oil will always be there.
3pointstar
The BEST system is the drain hose that comes out of the drain plug at the transom. I've had this for years and it's the best thing since no iron shirts! You can run the boat get the oil hotter than "satin's nards in leather pants" and when you put it on the trailer - pull over to the side- and drain the oil in a matter of minutes. no muss no fuss!!!
3pointstar
3pointstar
Padraig
3pointstar
3pointstar
Does anyone have any first hand experience if the oil pan drain hose kits can actually be used in a fountain 32 Fever or am I better off with the dipstick method on this boat? (It has twin MPI 502's and a single drain plug). It seems like there is a stringer in the way possibly and they would be hard to fish out of the drain plug but I may be wrong?
I would prefer the hose method if possible but I don't want to go through the hassle of ordering and attempting the install if it won't work or will be more of a PITA than the dipstick method.
If it is not possibe and the dipstick method is required, what kits/ equipment do you all use? I want something that will last, be hassle free and uncomplicated.
Forum Regulator
Some folks have actually installed 2 extra drain plugs, specific for the oil drain hoses. Just install them on either side of the stringer, about 2 inches above the bottom hole, and either side of the stringer. (Keeping them higher will keep them out of the way of any crud/water that drains out of the single bilge hole.)
