Sound Internet Technical Advice
#41
That should help with the soda pop theory.
#42
SORE MEMBER
1 Post
2 stroke pipes are a whole nother beast as they are built to hold and then put fresh air/fuel back into the cylinder, not just pull out exhaust to help the intake pull in air/fuel.
Nothing like your exhaust being an intake manifold too. LOL.
This .gif is great as a demonstration (2 stroke exhaust) of what I'm trying to say . LOL.
When I raced in the IKF nationals I carried over 20 pipes which is what sucked about 2 cycle.
However there are ways to tune 4 cycles for a particular application in a similar kind of way.
Examples would be:
Running wide open (circle track)
Accelerating (drag)
Mudding ( keeping water out of a submerged exhaust)
Marine (reversion)
Sounds simplistic, but those are only 4 that do not call for the same design
#45
Never the less the point is there are exhausts that are better suited for a particular need.
Examples would be:
Accelerating (drag)
Marine (reversion)
Examples would be:
Accelerating (drag)
Marine (reversion)
#46
Im thinking of building a 2 stroke marine motor now.
#47
A Tundra can tow a 42 ft fountain
You MUST have a diesel truck to tow anything bigger than 26 ft.
A bravo based drive is good for 800+ HP as long as "you are easy on the stix"...
What cam should I use to prevent reversion?
Brand X will always be better than brand Y
Your boat is worth 20% less than what you are selling it for
Baja owners drive vette's, Cigarette owners drive Porsche's
Skanks are better than hoe's...
