engine & drive lube??
I was wondering if anyone has tried the Pennzoil drive lube the marine synthetic gl-5 type and what is the best motor oil to use?
http://www.pennzoil.com/penn/product.../warranty.html
USED TONS OF MOBILE ONE AND RED LINE THEY BOTH WORK VERY WELL IN THE BRAVOS AND ALPHAS 75W90 !!!!!
ENGINE OILS ARE THE SAME MOBILE SEEMS TO DO GREAT REALLY PREVENT WEAR IN UNBLOWN APPS. BUT TENDS TO THIN OUT ON HARD RUNS WITH THE HEAT ,BLOWN MOTORS WE USE 20W50 AMSOIL OR REDLINE THEY DO GREAT AT KEEPING ITS VISCOSTY
AND CUTS DOWN ON WEAR LIKE YOU WOULD NOT BELIVE .
HOPE THIS HELPS E-MAIL IF YOU NEED MORE INFO
