Which way does the sea pump flow ?
mcollinstn , GREAT explanation ! THank you . I got the same thing from DanL on the phone . Thank you too Dan. I never realized the ports were offset . I am going out now to check the pump . What is my chance of havening damaged the impeller ? It had water pressure from the garden hose . MAybe that lubricated it ? Guess I have to check to be sure . Better to do it now then on the water ! THanks guys for all your help .
Yup the pump was mounted upside down in the bracket. I checked the other motor before install and just assumed this one would be the same . Oh well . Boy those hoses SUCK to get on those fittings !!!
I had to take a brake and calm down . Had to take the pump completly out and put it in the vise to get the hose on ! In order to get the pump out ,I had to remove blower , power steering pump , fuel line from filter to pump ,and 2 front water hoses !! IF I took the exhaust manifold off it would make it easier too. But I didn't. Then I bumped the fuel valves and dumped about 2 gallons in the bildge !!
I have a nice headache now ! MAybe by midnight I'll have it back together ......
![Mad](/forums/images/smilies/mad.gif)
Best to double clamp the hoses. I blew a hose off when I was testing early in the spring. Its surprising how fast those pumps can fill up a boat and how hard they are to get back on out in the lake. But it sounds like this advise will get there late. Good Luck
BillR
11
07-29-2022 06:31 AM
