Build a 650-700 hp engine. N/A or blower?
#43
So now that you determined that a stock 502 magnum or a 420 would be a economical base point for a blower motor where do you go from there?
Is a Procharger the most efficient blower out there? Can you get away without an inter cooler on it. ? Or would you be better with a under driven 420 or 8-71 without a cooler so you might be able to keep it under the hatches?
#47
Your mileage may vary
#49
I originally had Chief Blower Motors in my 1993 Top Gun before I upgraded them. They were 502's with 671 and aluminum heads. They made 690HP and had no intercoolers. They ran over 500 HRS, with only the top end refreshed once. Many times with the throttles against the dash, 5-6 lbs of boost. No issues not having intercoolers. Ran like a top
#50
I have 700hp blower motors and love them.
That said, I would take 700 N/A motors any day for the fact they have way fewer moving parts, belts, and potential for things to go wrong and if built right can run on 89 octane. I am running 93 octane which is getting harder to find on the water.
