Start to Finish: Building Our 50' Skater
#1121
Yeah that's a great use for a CSP/DSP slot. Can set throttle based torque table where low end is normal but upper rows are flat and conservative. Half to WOT might only be a 100hp difference. I think you'll really like the power that EFIlive tuning offers in that setup. It's not as versatile as a true Bosch MS ecm, but that 10k savings buys a lot of tuning time..
My experience with EGT is that throttle position, boost, load, RPM and EGT run very linear. The only differences occur with prop changes. A 35P would spin 3850R / 79mph at about 1400F and 75% calculated load. The same dia prop in a 38P spun 3650R / 81mph at about 1550F showing 90% load. All in the same tune. I tested this same math on my 5.9L truck last week pulling a 11k boat up a long hill in VA. Tow haul mode vs regular. Load and EGT tracked hand in hand.
#1122
We were in a hurry trying to put a radiator on the engine cooling water to be able to make longer dyno pulls and the first long pull we made the hose touched the intake pipe and melted a hole in it. Which was actually a good thing that we had that problem because it let me know that I need to insulate the intake pipe too. It will not get as hot as the exhaust but it might still get to 400-600 degrees.
#1123
If a big single turbo falls on its face before getting on plane maybe a compound turbocharger setup using borgwarner sxe turbos would do the job. Maybe a borgwarner s366sxe or s369sxe with an s480sxe+ or s500 on top. Also you will see a drop in EGTs and it will get on plane very quick.
#1125
#1127
we have tested 18-20 different turbos on the engine so far, different sizes, ratios, and manufactures. I'm sure we will have 50 different turbos on it by the time we're happy with it in the boat.
When your doing experimental testing of something that has never been done you have some problems. We have blown a few turbos up from over speeding them, ect. There were a couple that had some bad castings and we went through three in one hour, then measured it and the cartridge was machined at an angle.
here is a video of one of them locking up under wide open throttle.
#1128
The boat sure looks different with the M8s on it. The hatches are still open, just waiting for you to get some motors put back in it! Lol..... Is your V ready to run? I didn't look up inside to see if the motors are in it or not. Good luck on getting your new motors dialed-in Tyson.
#1129
I found a 12 channel EGT gauge. Does anyone know of any other 6 or 12 channel exhaust gas temp gauges? This would be pretty handy with the two 6 cylinder engines. I can just give a quick glance and know that all the exhaust temps are ok and it has audible warnings you can hook up. The only problem is that it's not water proof. I would have to make some kind of housing for it and have a way to get to the knob. Possibly o-ring the knob through a housing with a lexan front?
#1130
I know edge products makes EAS gauges and it goes to a monitor. You should be able to get both readings on one screen. Not waterproof. Another good idea is possibly using EZLYNK but im not sure if your ecms are compatible. EZLYNK is all bluetooth and the gauges read on an android device. You can also use ez lynk in place of efi live and load files onto the boat with your cell phone wirelessly. They also have a shift on the fly tuning switch.
