Start to Finish: Building Our 50' Skater
#1161
We mainly use solidworks but have one guy that uses fusion. fusion would be a lot cheaper and easier to learn, and it does basically the same thing.
#1162
Bell housing screw up:
When it's 2 am you should not be loading tools for the machine and I guess I did not get the end mill tightened good enough and it started pulling out of the holder and went through the part where we were making a lightening pocket. You can see in the upper pocket it started pulling out and going deeper as it went around making a pyramid then on the next pocket it went through.
If this was a customers part we would have to start over and it would be a costly mistake. But since its mine where the hole is at it does not matter . I was going to machine a couple of holes into it after I test fit it in the boat so I can see inside to inspect the spring dampener and for water drainage and its on the backside under the engine so I will just call it an inspection port. Had the end mill pulled out a little sooner when it was doing the flat part it would have ruined the part.
![Smilie](/forums/images/smilies/smile.gif)
I have done that same thing, I stopped using collets for that reason, seems like the harder you push them they will start pulling down and wreck the part, and I wouldn't want to have to remake that part. That's got to be 8+hr.
Really interested to see how your Diesel hold up, I have been around high performance diesel for a LONG time and most stock block don't like the abuse of holding it 1k for long periods of time. I hope I'm wrong as you have a ton of money sitting out there at II.
#1163
Kidturbo that's exactly what I was thinking of, this would give loads of options to fine tune the setup.
This is going to be the next modification on mine although I need an external unit with around a 6" drop and I don't think SCS or Arneson do a 6 with changeable gears.
#1164
I do not know who Jim is but it is not me , unless Jim Lives in Cancun MX and has a double personality
If you have a machine shop you could make a new product line selling those bellhousings, this Cummins build is going to get many people thinking about going with light high power diesels
I thought about it before but diesels horsepower to weight ratio does not always make sense.But after watching youtube videos of 4x4 trucks pulling 8 second 1/4 miles things in the brain start to imagine and working, then comes your posts with your megayacht skater..imagine no more rebuilding engines every 150 hours.
eye candy:
Did he say 0-60 in one second?...engine porn
![Cool Smiley 011](/forums/images/smilies/cool-smiley-011.gif)
#1165
Tyson,
I must say this thread is very impresive. I just finished reading it from start to finish. The amount of work you and your wife have put into this project is amazing. Everything hand made, he even made his own transmissions for his first go at it with the first set of motors.... all I have to say is WOW! And good luck with your endurance run!
If you need a paramedic/firefighter/ex soldier /backwoodsmech I'm your guy..... I see there is plenty of seats![Cool](/forums/images/smilies/cool.gif)
subscribing....
subscribing....
#1166
If your interested I have a dozen or so spare cases, extra shafts, and many assorted gear sets. Don't see us ever using all of it. I know Pat still cuts gears for these, so might be an option for ya. As Tyson can attest, after the first one, it's simply load material, hit run button, repeat.. lol
Also know someone who modified an ASD8 chain drop to 6". He said it was actually easy, I'll try to get ya some pics. Only had to machine out some new bearing bosses and shorten the chain.
#1168
Looks like emissions could be a big problem! do the Cummins really smoke that much at 1000hp + ?
Can they really turn 6500 rpm for more than a few seconds?
#1169
6500rpm aint going to happen at least for very long with a stock blocked cummins. Not unless you make it a 13:1 motor and plan on starting it on ether ever time. You would greatly have to lighten the rotating mass up so the block would stop moving at those rpms for any length of time. I cant remember what the number are off the top of my head by the difference in stress on the crank and the main caps from 4500rpm to 6500rpm is something like 45x more. The main caps walk almost 4x more then the bearing tolerance allow. Granted this is for a mS when you see the highest Cylinder Pressures.
