Start to Finish: Building Our 50' Skater
#111
We have two epirb's and we will both have fanny packs on with personal gps locators.
Lots of safety gear, water makers, medical kits, food, ect., on the Bermuda run we had around 1500 lbs of safety gear.
#112
Hitting floating debris or even a whale is one of our biggest fears. There are thousands of shipping containers that are floating right at the surface that we could hit. even logs and stuff will make it all around the world. But there is nothing we can do about it but just pay a lot of attention and do the best we can to miss stuff.
#113
when it comes to debris : big ocean small mine little chance of hitting one
the added bonus of all the debris is you'll be setting a record for running the longest obstacle course
that's pretty amazing the prop slip over that much of a weight change
i don't much hasn't been thought and rethought not just on the boat but safety and security as well
#114
On the cockpit drains Why not weld a stainless screen on the back side of the cockpit drains to stop items from going out the back of the boat. Just my 2 cents.
Very cool build , wish u all the luck in the world ..
#115
I'm sure u have the bussle there for a reason , but I would think if u get caught in ruff water and have to idle or go slow for a while that the bussle will be fractured by the force of the water . Is there a way the water is relieved upon re entry into the water. Otherwise I think the law of hydraulic's will take over..
When you are out in the middle of the ocean holding onto a shiny prop behind a boat you look like spinner bait to a shark.
My bussle is really high and its a lot thicker then you see in the mockup pics. The tunnel extension is going to take the most abuse and we have made it one of the strongest parts of the boat. The top of the tunnel extension is over two feet lower then the bussle so it should slow the boat down a lot on re-entry before the bussle hits. I also have the twin fin Arneson which will block the water from coming up to hit the bussle.
I will post pics of it finished tonight.
#118
it would be great if we can track your progress and where you are in the world
will you have a satellite tracking device like SPOT where someone can upload the map images here in OSO so we know which ocean you're conquering
pic of a sample SPOT (but on land)
Photo Credit: https://gearjunkie.com/spot-gen3-gps-satellite-tracker
![](http://i1238.photobucket.com/albums/ff488/Noli1012/survival_equipment/15415.jpg)
#119
Tyson that's exactly the same configuration I am going to run on my Arneson/Diesel boat without the digital side, I am just running the mechanical gauges to realign the drives if they drift out of line.
I am sure you have already thought of this but one thing I added to my engines was a mechanical flap on the turbo intakes to starve the engine of air in a runaway situation, just incase you have a turbo failure.
J
J
#120
This time it will be a live tracking map not just a spot every ten minuites like the spot trackers are. (It will be turned off on certain trips at bad locations i.e. NE Coast of Africa.)
We will also have a live chart that will show when we started, our average speed, distance to go, time left to beat record, speed needed to beat record, fuel started with, fuel burn rate, fuel left in the boat, fuel needed to finish, ect.
And we will have live vital signs with heart rate, blood pressure, ect. We will be wearing wireless G-load sensors on our bodies and one on the boat that will show the g's were taking and maximum loads and number of hits at each load range.
And several live cameras that you will be able to log in and see in the engine compartments, in the cockpit from different angles, the drives, and out of the boat at different angles.
