Start to Finish: Building Our 50' Skater
#1191
Exhaust:
We decided to have a Heat shield blanket made for the exhaust manifold, adapter, and turbo housing instead of trying to water jacket all the parts.
To water jacket the parts would have added a lot of weight, taken a long time to make, and would have caused the engine to make less hp and be less efficient.
Now we will just have to see how hot the outside of the blanket gets with sustained high temp running.
The heat blanket will be painted with black high temp paint that will soak into the fibers and will look like the other attached pics when done.
#1193
The only reason to do a water jacketed turbo is to not catch something on fire or burn yourself. The heat itself will not hurt the exhaust housing.
I had non water jacketed turbos in my Apache cat for 7 years and never had a turbo failure. Every once in awhile I would loose water pressure for some reason or another and the aluminum manifold would melt and send the aluminum through the turbo and it would eat it and spit it out the back. A few times the aluminum would pack in front of the turbo where I had to use muriatic acid to eat the aluminum to get it out of the housing, but then would put the same turbo right back in the boat. I was running 1600' exhaust temp in the Apache Cat.
#1195
I believe he was talking about a water cooled cartridge, or the center bearing assembly rather than exhaust housing.. That's the important part Cummins seems to skip, but everyone else uses.. I also prefer roller bearings if possible, which basically lasts forever even heavily loaded...
#1199
Cup holders:
Now for the most important custom parts in the whole build...... The cup holders.... A lot of people use the big "Yeti" style tumblers/ cups. The problem is they are way to big for normal cup holders. We decided to make some cup holders that will hold the large yeti tumblers. These pics have a normal size cup holder and my cup holders. It will also hold the yeti can/small bottle holder with out it falling out. And cell phones will fit completely down in the cup holder and not fall out in rough water.
I also have Silicone tape that we can put around the top inch of the cup holder to keep the tumbler from rattling or scratching the custom painted tumblers.
#1200
Nice. I installed cup holders which also had Rod holders in the bottom in my console so I could stick the Hydra Shade umbrella in and give a quick twist to secure the umbrella with no ropes for quick shade while idling or rafting.
https://www.hydrashade.com/
http://www.mateseries.com/
