Start to Finish: Building Our 50' Skater
#1302
#1303
https://youtu.be/8zegGFszRL0
You must not be as much of a stalker.
Here is the video. Sorry I didn't post it earlier but I have been busy today. Thank you for the people that watched it for not posting link so I could.
One heck of a project, Awesome amount of work and dedication.
#1305
I have not mounted the tabs yet. When I had arnesons there was no place to put the tabs but now that I have 8's I am going to put the tabs on it but have not had the time yet. I have not hooked up the drive indicators either, that's why there all the way up also.
#1306
Hope the engine issue is not a big set back for you. One thing to note though...that windshield does one heck of a job. I did not see any buffeting on you when running. Passenger's hoody didn't move.
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
#1307
Composure on that video is remarkable. 1:45 on.
#1308
Finally, the video that OSO has been waiting for!! Good to see her on the water despite the conditions.
Looked like a pretty large RFP spike (judging by the roost) at the 1:53 mark right prior to the engine noise.
Hoping its something minor.
Thanks for sharing Tyson.
#1309
Yes the windshield works really good. We left the windshield taller then most because of my suspension seats. We sit higher to have the 8" of travel in the seat. With the seats up we are about the same distance below the edge that someone would be at in a normal skater but for some reason the little bit higher/longer windshield deflects the air better. If you notice the seatbelts in the back are just hanging and not blowing around at all.
#1310
One thing we did not think of when we moved the turbo to the side instead of it being behind the engine was the hatch actuator. I had measured to make sure the hatch actuator would clear but I never measured or even thought about it after we finished the engines. I used a longer bolt to move it farther forward but it still was touching when its all the way up and it hits the engine more the lower the hatch goes. If you notice in the video the hatches are up that was part of the reason. I would have ran with them up to start with anyways just to be able to look the engines over real quick or fix any major leaks, ect. quick, but I would have eventually lowered them. It does not sound like a big problem to move the actuator but they are through bolted which means paint work ect.
