Start to Finish: Building Our 50' Skater
#1502
When I was driving towards SLC I started calling truck washes to see if anyone would be open, There was only one that was open and it was going to close at 4 pm and not open till tuesday. It was 9:36 am and my gps said I was 6 hours away. I ask them if they were going to stop washing at 4 or stop the line from adding up at 4. They said if I was in line by 4 that they would wash it. Keep in mind the gps is figuring on speed you would run in a car, not a Freighliner hauling a big boat through the mountains. So I started driving as fast as I could knowing it would slow down going up hills and I would have to make up that time going down hills. I did not stop for lunch, pulled into one truck stop and put in a little fuel as quick as I could to make sure I would make it. While I was driving I called everywhere trying to find a manual car wash that a semi would fit in and could not find anywhere to wash it if I did not make it in time. I ended up calling a guy that I have never met that lives in SLC that is having a new Skater built and was asking him if he knew of any car washes it would fit in. He said there were not any but to just bring it to his house and he has warm water hose hookup and brushes, boat soap, ect. . He said he likes cleaning boats and that he would help me wash it. So I kept trying to make it to the truck wash so we would not have to spend new years eve in the cold washing the boat.
After some pretty insane driving I make it to the truck wash at 3:48 pm and they had yellow caution tape across the entrance and closed signs in the driveway. I went in and talked to them and they said they had told me that so to go ahead and pull around. They washed it and I gave each of the guys in there a tip for staying. They did a good job on the truck (because thats what they do) but did not get the trailer and boat as good as I wanted so I headed over to the Guy that is building a new Skaters house to touch up the trailer and make sure I get the tilt mechanism and air bag suspension system and leveling brackets good because it would be bad if that stuff rusted. When I get there he has hoses strung out to the street a wash bucket with soap and water and brushes ready. He starts scrubbing the trailer and I was following him rinsing it. He is laying on the ground scrubbing the bottom of the trailer and axles, ect. ( keep in mind I have never met him before and its cold and dark out on new years eve, this is what Skater guys do for people) We got it all washed and it looks new again. The trailer is still black again and did not rust away. So to the original question in the post, yes you can haul in the winter, just clean it good when you stop.
#1503
Tyson, I have been using a combination of Fluid Film and WD40 sprayed out of a pump up garden sprayer for corrosion resistance due to salted roads here in Illinois. I basically spray it on the entire underneath of my Jeep daily driver. You could use it on the mechanical and uncoated parts of your trailer for the return trip home. Good luck with the testing!
Ive used this stuff also before. it does seem to help quite a bit for keeping vehicles nicer for longer with dealing with michigan winters. probably wouldnt be a abd idea to hit the trailer parts with it.
#1505
We just put fuel in the boat , should be there at 10:30 - 10:40 depends on how many more hills I have to go up.
https://stateparks.utah.gov/parks/jo...nt-conditions/
#1510
Just logged on the cam to see and happen to catch you backing down the ramp. Good luck! Hope all goes well
