Start to Finish: Building Our 50' Skater >
Old 01-06-2018, 12:16 PM
  #1541
BigSilverCat's Avatar
Video: testing at Jordanelle reservoir.
check out the view/water at 2 min 15 sec
https://youtu.be/gdji3DtCmDA
BigSilverCat is offline
Old 01-06-2018, 12:48 PM
  #1542
Dead calm....deck camera from a 50' Skater on calm water is in keeping of the deck cam on a aircraft carrier.
Not many people can say they have ever gone to the lengths you have Tyson!
speicher lane is offline
Old 01-06-2018, 02:43 PM
  #1543
Thanks for putting the time into sharing this thread it is the best. Great job you are doing on the boat . Wisseman were developing a 2 speed that was air operated and went onto an outboard trunk above the gearbox i saw it at SEMA back in 2010 or 2011, maybe they do one to go on an M8 .Good luck with this project it is absolutely the best thing I have ever seen online!
Salstrip is offline
Old 01-06-2018, 02:55 PM
  #1544
SB
Received 3,279 Likes on 1,469 Posts
Crappy day there for sure. Mid to high 30's with a wintry mix coming down,
See a car at end of ramp so assuming they are still out there now?
https://stateparks.utah.gov/parks/jo...nt-conditions/
SB is offline
Old 01-06-2018, 03:24 PM
  #1545
we already left, here is the video of going back to industrial injections shop.
Old 01-06-2018, 03:38 PM
  #1546
What speed were you seeing around the 10 minute mark in the video?
Looking Good.
tommymonza is offline
Old 01-06-2018, 03:53 PM
  #1547
Looking Good.
it looks fast but it was only around 95 mph,
if you notice the roost turns dark on the starboard side right at 9:40 that was when the turbo broke loose so the engine was not getting enough air to burn all the fuel and clean up the exhaust.
Old 01-06-2018, 04:11 PM
  #1548
SB
https://youtu.be/XPatqS4XFgo
I quoted so we could see the link.
SB is offline
Old 01-06-2018, 06:03 PM
  #1549
Originally Posted by HabanaJoe
Tyson - a bit of advice and maybe you are doing it already but you should monitor exhaust manifold pressure (not back pressure but between exhaust ports and turbo) and that should be right along side boost pressure, you know boost has to be higher than exhaust, when it is not the engine can't breath anymore and things melt - again not an expert just years of looking over damage.
the turbine and compressor can be sized so that this statement is false
hogie roll is offline
Old 01-06-2018, 06:33 PM
  #1550
That starboard engine didn't look happy from the get go, it seemed to be steaming heavily at the start compared to the port.
Whats making to turbos let go? they should be the simplest part of the project if matched to the engine correctly and not over-speeding.
Here's one of my turbos off my motors what size inducer and exducer you running?
Attached Thumbnails Start to Finish: Building Our 50' Skater-img_3159.jpg
999JAY is offline
