Start to Finish: Building Our 50' Skater >
Old 04-05-2018, 10:10 AM
  #1701
That is frickin HILARIOUS!
NASCAT is offline
Old 04-05-2018, 10:21 AM
  #1702
Knot 4 Me's Avatar
Now that's a turbo!
Knot 4 Me is offline
Old 04-05-2018, 10:26 AM
  #1703
Can you say "LAG"
AZMIDLYF is offline
Old 04-18-2018, 01:17 PM
  #1704
BigSilverCat's Avatar
Pistons:
When we ran the boat at Lake Havasu a few weeks ago one of the engines started making a little bit different noise and had more blow by then the other. Every time we have ran the boat it has been in really cold water. At the lake in Michigan it was 34' outside and 35' water temp. At Jordanelle reservoir it was 36' outside and 32' water temp, and at lake Havasu it was 60' outside and 55' water temp. The engines do not have closed cooling so they are getting continuous cold water and the blocks are not getting warm, maybe up to 100 degrees. So we think the pistons are swelling in the bore and the block is not getting warm enough to grow so the pistons are expanding and grabbing the side walls. Now I need to figure out a way to use a thermostat to have the water circulate in the engine till it gets warm and then let the raw water start coming in to cool it. Something like a merc 1075 uses? Any ideas?
On another note, the top of the piston looks basically new. No real signs of melting, ect. and we ran them really hot a few times.
BigSilverCat is offline
Old 04-18-2018, 01:43 PM
  #1705
Thermostat is must in cold conditions, but it should be circulated. When thermostat closed, full flow trough engine is needed. Three way thermostat is way to go. For example this
https://www.totalparts.nl/eng/truck-...2016-2017-2018
scania part numbers 1381494 1381494. Bigger fittings are two inch dia. Simple put anywhere between
https://www.truckparts1919.com/media...-5058452_2.jpg
It have two step double thermostat inside. First is lower temp and shut circulating flow and open cold flow. If flow is not enough and temp rise, another thermostat open and double the flow.
ksalmine is offline
Old 04-18-2018, 01:45 PM
  #1706
SORE MEMBER
Wobble's Avatar
Closed cooling and regulate outside water flow to water/coolant exchanger. This would have the added benefit of reducing hot spots due to air pockets and corrosion. Maybe one exchanger to service both engines?
Wobble is offline
Old 04-18-2018, 02:34 PM
  #1707
We do not want to do closed cooling due to the weight and size needed to cool this much hp.
Old 04-18-2018, 02:37 PM
  #1708
PigNaPoke's Avatar
Originally Posted by Skater30
Check out this website Tyson - I've had these on my trucks for many years - they work great! If you look close at the attached pic, you can see them about flush with the bottom of the body. I can get you close up pictures of them on my truck if you'd like.
Browse Our Wholesale Truck Accessories at AMP Research
i have a set on my truck as well. Never had an issue.
PigNaPoke is offline
Old 04-18-2018, 02:40 PM
  #1709
Something like this? Thermostat with a bypass. Use the stock water pump to circulate the water till it’s warm and then the bypass opens and the raw water will go through the engine.
Old 04-18-2018, 03:02 PM
  #1710
SORE MEMBER
Wobble's Avatar
Understood, but if you exclude the intercoolers which I assume are already raw water cooled. Water/coolant exhangers are very efficient if designed properly. The only other add on is a circulation pump. I'm guessing that you have already looked into it and have a weight in mind.
There are surely lighter solutions than those you would see on a marine CAT
Wobble is offline
