Start to Finish: Building Our 50' Skater
#231
Here is a video of the suspension going up and down. The fenders are twisting because they are bolted to the torsion arms. notice the distance from the tire to fender does not change.
https://youtu.be/TP3tooitX7Q
![Party Smiley 004](/forums/images/smilies/party-smiley-004.gif)
It appeared you were lowering & raising all 4 at the same time.
There's enough travel to get a wheel & tire off the ground w/ the weight of the boat on the trailer?
Our race haulers still require a jack to change the tire even if we dump the air bags. Just lightens the load a bit.
#234
Since the axles have self leveling, when we pick one up the others will compensate and the ride height will be the same, that will give us the travel to pull one off the ground.
And we are not only dumping the air, we have a vacuum pump and tank and were lifting the wheel off the ground
#235
Right, cause the fenders don't move. The tire and fender gap never changes. Only the height of the frame moves. Guess I'm missing something, he said that all 4 axles were lift axles as well I thought?
#236
When I say lift the axles I mean the end of the axle where the wheels are. The axles are welded to the frame solid.
#237
Tyson this is the most impressive well thought out build I have seen. Thank you for sharing. Anyone ever questioning the true pioneer and visionary in performance cat design and production should have few questions after seeing what you and Pete have accomplished in this build.
Good luck on all your endeavors and I would love to help anytime anywhere if you need additional crew.
#238
Sign me up too. Tyson knows this boat forwards and backwards now since he built it. His ability to troubleshoot and correct problems will be unrivaled by any other boat owner. This is a boaters boat. This thing will be able to do anything anywhere.....in the world!
#239
I agree, this is something special. I think even more so then any of us comprehend or realize at this very moment.
