Start to Finish: Building Our 50' Skater
#281
Some may call you OCD or rate your NERD level but IMO it's simply attention to detail.
Extra detail given to items that have absolutely NO functional benefit (like Philips screw head alignment) well we call those "Style Points" and those are worth a few mental 10ths of a second within the NASCAR garage. I say this b/c they place the competition in awe not to mention the distraction it causes them as they wonder how much time we put into the details that really count if we were willing to invest time in the non performance ones.
PS- all the external hardware on my boat is aligned as are all the outlet and switch plate screws in my home.
#283
#284
The valve body for my transmission. The transmission will be electric shift. I have designed and built a transmission that does not work like any transmission that has ever been built. Kind of risky, but I'm 99% sure its going to work. It will be able to run full time in forward and full time in reverse so that if we break props and have two that are left that spin the same direction we will just run a little slower but still be able to run. The added benefit is that we can run the props turning in or turning out just by flipping a switch. If were full of gas and the water is rough the first half we may run turning in if its more efficient that way. Then half way stop and switch the props to spinning out and run faster in the smooth water while were light on fuel. I made it so we can pull a cover off and replace a part to lock it in gear where it just becomes direct drive if the clutches burn up, pump or valve body fail.
Another thing with being electric shift, electronic throttle and autopilot, is I have the ability to run the boat by remote control. That will make unloading at the ramp easier by myself. I will just back down, unhook the bow eye and get back in the truck and start the boats engines, back it off the trailer into the middle of the lake, go park the truck and trailer then walk down to the dock and have the boat drive it self up to get me.
[ATTACH=CONFIG]552623[/ATTACH]
I'CE (04-11-2024)
#285
[ATTACH=CONFIG]552623[/ATTACH][/QUOTE]
You would just be showing off at that point.
#286
Make sure the batteries are charged in your remote! Had a show off come into our marina with a 55' aft cabin yacht, gets the boat about lined up, climbs off the swim platform with his fancy controller and then it died while the boat was all crossed up and he's on the dock lol pretty priceless
#287
The SIMRAD gps screens. We have a 19" in the middle, 2 - 12" on the front sides, and a 16" in the back of the console. This gives us the ability to leave one screen on an overview of our path, basically zoomed out. And then we each have our own screen to zoom in and out or check different paths, ect.
And the one on the back of the console will be controlled by a remote mounted next to one of the back seats for the person in the back to be able to help navigate.
[ATTACH=CONFIG]552624[/ATTACH][ATTACH=CONFIG]552625[/ATTACH]
#288
I think you need to switch things up and just provide the thread followers w/ a list of your oversights b/c I'm thinking that would be way shorter or maybe a blank sheet of paper.
You have covered so many details and possible scenarios as you've designed and built this boat it's absolutely incredible.
