Start to Finish: Building Our 50' Skater
#411
Pretty much, I kind of got out of order with posting the photos so there are a few other things I will try to dig through my photos to post that might be interesting to some people. I drove home yesterday to finish machining the transmission parts and some different seat brackets. And I found some old race boat exhaust in there barn that I brought home to try to use to make the tail pipe from turbo out the back of the boat. This was two pieces that I have tacked together at the top in the middle. I will have to cut the outside jacket back an inch and weld the inside pieces together and then weld a sleeve on the outside. I will leave a dam in the water jacket up most of the way to the top so it will force water up and not get an air pocket. I will have to cut off and turn the water hose inlets a different direction. And fill in a few of there fittings that I will not need, put a different flange on the front to clamp to the turbo. Then extend the outlet about 6" to go through the transom out the back of the boat. Besides all that work these were pretty much perfect. They go out the turbo and go up to right under the deck to get the most height we can get then swoop back down to make a vertical wall inside there that the water would have to climb to get into the engine.
[ATTACH=CONFIG]553075[/ATTACH][ATTACH=CONFIG]553076[/ATTACH][ATTACH=CONFIG]553077[/ATTACH]
#412
So what are you looking at as far as a timeline to trying the around the world run? I know you said testing and tuning this summer so are you thinking as early as next year or more like a few years out? Looking forward to following your progress. Also as far as all the plugs and air bags to keep her afloat in case something bad happens just bring a case of flex seal lol. Obviously I'm kidding
#413
I wanted to do this for the exhaust but Pete said no....
how cool would this be in the turbine boat with the flames coming out the dragons mouth..
[ATTACH=CONFIG]553089[/ATTACH]
#414
#416
VP of the tickfaw200
#417
I was not going to be able to through bolt the bilge pump so I bent and milled a piece of aluminum that has a flat to glue to the wall and a notch for the t-clamp to go through it.
[ATTACH=CONFIG]553099[/ATTACH][ATTACH=CONFIG]553100[/ATTACH][ATTACH=CONFIG]553101[/ATTACH][ATTACH=CONFIG]553102[/ATTACH][ATTACH=CONFIG]553103[/ATTACH]
#418
Looking at those fittings that go onto the sea strainers I would image the id is fairly restrictive, I think your idea of running the charge cooler on a separate water pickup and strainer is a wise choice to increase flow to the motor, my Nortech was rigged this way when it had blower motors.
What about corrosion if you are going raw water cooled, is the billet hardware more resilient than cast aluminium or is the exposure duration to salt water not going to be long enough to worry about.
#419
#420
Sounds well sorted, engines should be a breakthrough in diesel applications, what will the TBA be in 1200hp configuration?
Are the transmissions multi speed? what about driveline UJ or CV?
