Start to Finish: Building Our 50' Skater
#831
#832
#834
Damn I missed that engine at sema. You know there is no way to see it all.
#836
Ok, back to posting some pics.
we made some custom prop shaft covers for the boat.
[ATTACH=CONFIG]561659[/ATTACH][ATTACH=CONFIG]561660[/ATTACH][ATTACH=CONFIG]561661[/ATTACH]
#837
Blow out tube:
The first time I took the boat to the water I was rushing to get a quick test to make sure the transmissions worked, steering, ect. and to make sure the boat would float.. before it was going to be tied up getting a special coating on the whole boat ( I will post more on this tonight).
I knew I would need blow out tubes for the props but did not have time to make them so when we tried to get on plane we could not get any boost so it had no power. While the coating was being put on the boat I made the blow out tubes. Was not sure what size I would need so I went big, there 4" dia piece of stainless elbow with a collar welded to it for the rubber hose to clamp to then some gussets and flanges welded to the bottom to bolt down on the arneson.
They ended up being too big and once it broke loose the prop would not get enough bite to get on plane so now I have just a 2" dia piece of rubber till we get more testing done.
[ATTACH=CONFIG]561666[/ATTACH][ATTACH=CONFIG]561667[/ATTACH]
[ATTACH=CONFIG]561662[/ATTACH][ATTACH=CONFIG]561663[/ATTACH][ATTACH=CONFIG]561664[/ATTACH][ATTACH=CONFIG]561665[/ATTACH]
#838
