Start to Finish: Building Our 50' Skater
#891
There are other carbon coatings out there in the detailing arenas. I have personally not tried any yet but just might now after seeing this. It is not cheap but not too expensive to give it a try at home. Here is one from a company I have been buying detailing products for my boat and cars.
http://www.chemicalguys.com/Carbon_F...s_p/wac227.htm
#892
https://www.youtube.com/watch?v=9rMcRJVY1-0
Alright, I'm pissed....you have found some new Clark Griswold sled lube that none of us have and now we are all chomping at the bit for a quote.
Something else ole Pete can upsell us on....
I'm thinking for $12k-$17k and no guarantee how well it works nor documented length of time it lasts I could probably find time in my day to clean my boat.
My boat also isn't a 50' x 12' canvas.
Updates over time will be interesting.
In reference to a slick hull I was under the impression that a slick running surface was actually slower than a scuff prepped running surface.
In theory a sanded bottom would be faster then a smooth bottom. The water tension would make it just touch the tops of the sanding ridges which would be less surface area in contact. This coating is supposed to kind of do the same thing, its hydrophobic so water will not sheet on it which would cause lots of surface tension. If the water technically beads on the bottom when your running and does not stick to the surface then it should help. Another thing is we plan on being in the water a lot and if you had a sanded bottom it would be good for the first time then it would slow you down from the growth on it, that is where this coating should have the advantage. If we are sitting in the water for a week and have a lot of growth on the bottom is should just blow right off the minute we get on plane.
We make a Ceramic now and I can tell you they are a ***** to put on. And ours is now classified the working mans ceramic. They work but there is sure no guarantees. They last in auto world, not sure about marine world. Also at $250 a foot that has to include correction, fixing all scratches and imperfections etc.
Just from the little experience I have with this coating so far and the years of experience I have with sealer waxes and Synthetic waxes I would say this is definitely better so far. But it is expensive. I have never waxed any of my boats, I don't believe in wax. I polish them, just don't add anything back that would create a dirt magnet.
#893
A local boat spent 10k on a ceramic coating, after the first year, it looks like ****. It was done by a certified Ceramic Pro installer as well. Hopefully you have better luck!
#894
I need some help.... Do any of you guys have rzr's or dune buggys, side by side's, ect. that have seat belt harnesses with sleeves on them? My seat belts have an edge in them that hurts your shoulder and I want to find a good sleeve to put on it maybe out of neoprene? Any ideas?
[ATTACH=CONFIG]561804[/ATTACH][ATTACH=CONFIG]561805[/ATTACH][ATTACH=CONFIG]561806[/ATTACH]
#896
#900
https://www.aliexpress.com/cheap/che...eat-belts.html
