In Hull transducer help
I have a 1989 30' Regal Velocity Steve Stepp hull and just got a Garmin 741xs. I am looking to install an in-hull transducer but not sure if my hull is a cored hull. Any ideas?
You can royally screw up a post and we will still help you.. We are going to bust your balls about it, but we will still help.
It is kind of like how we w.ill laugh and cheer as our drunk buddy falls off the dock, but we aren't going too let him drown
I think most Velocity were all balsa cored. An in-hull transducer will not work right unless you cut through the first layer, grind/dig out the coring. Reglass it so that you seal the integrity of hull.
You can now epoxy the transducer housing to the hull.
Make sure when you insert it you get the angle correct in regards to the vee of the hull. I would think it is around 20 degrees or so.
