What the Puck to do about Lavorsi's GPS Antenna?
Apparently if you have an older style Gaffrig/Lavorsi Speedo (or three as in my case) with a battery powered puck-style antenna and your battery is dead - you are now pucked. Lavorsi doesn't sell replacement antennas and now they no longer offer a replacement service for your battery. Apparently you can't just change the battery yourself because according to Lavorsi the antenna requires a software reboot after the battery has been changed. The new Lavorsi solution: buy a completely new gauge and antenna from Lavorsi for over $550 instead of just replacing your battery.
Does anyone know a way around this?
I don't remember what puck(looks like a computer mouse) I have but I replaced the battery and it worked afterwards. I had to unsolder a tin cover to get to the battery, then unsolder the battery. The replacement battery was a little different (connectors) but I was able to tweak them and get it to work. That was 5 years ago now. Still works.
Not sure this helps, just in case your phone person told you incorrect info. This will help you double check:
http://www.livorsi.com/auto/pdf/gps_...placements.pdf
Okay, some quick and unique searching go to me to a good thread on Scream and Fly, and itlooks like a guy there can fix them. You can read whole thread, but below link get's you to the meat faster. His screen name is luv2gofast.
Link: http://www.screamandfly.com/showthre...-replace/page4
