Prop shaft bolt
Prop shaft bolt
While I'm at it with the outdrives here's a pic of the prop shaft bolt (lost one & need to replace)
the size is 1-7/16"...........I don't suppose you can find one at big box stores?
Charter Member #394
The prop nut you need size is 1.0-14. The wrench size is 1-7/16".
Mercruiser part no. 11-826711-27.
You should be changing these when the nyloc starts to wear out (the nut is easier to spin on).
This is the only safety keeping the prop on, no other lock for the nut.
