Polish/Wax
#34
My uncle is in the auto body business. So I get pro 3m stuff or Meguiar's via his suppliers. The major difference from consumer products is the pro stuff is designed for use with pro buffer machines. The consumer products are fine on newer finishes. But older stuff the pro stuff brings it back to new better then regular consumer products.
#35
Funny that no one has mentioned Performance Boat Candy yet. Maybe I should be looking for a new product.
What product is recommended for washing the boat after applying the Ultracoat Paint Sealant? What about a quick detailer spray between waxes and how often??
#37
Yes use the spray every time you pull the boat out of the water and wipe down. Wax when scum lines don't easily wipe off with just your finger.
#39
I tried their kit. Didn't work any better than plain ole Starbrite PTEF wax and Turtle Wax Detailer/Spray wax. Wasn't impressed enough to go out of my way and order it versus pick the other cheaper crap up at Wally World.
#40
I'm not a pro. I don't have access to "pro" product. But I did take a tremendous amount of time in researching what product to use, how to apply, and how to extend results.
A painted boat with clear is just like a car. The clear gets bombarded with contaminants and gets swirl marks. No different than a car that needs paint restoration to restore the finish, remove swirl marks, and protect it from the elements. In short, there is a process that needs to be followed and there are a ton of great POLYMER products on the market. Here is what I bought and used. I was blown away with the quality, ease of application, and end result. Before anything, I clayed the entire boat from the chine to the deck. Yes, it took a long time. But now that it is done I'll be maintaining it and not having to go through the entire process in the spring.
http://www.autogeek.net/wolfgang-swirl-kit.html
Collinite 845 is a great sealant. I was going to use it after I used the Wolfgang sealant as that is a process many use. Some people apply two coats of the Wolfgang sealant. I ended up only needing one and I was done but I do have a bottle of 845 on the shelf if I decide to give it a try.
