remove or stack your stickers
I peel it every two years when renewed. I found that if you leave the stickers on there, they get very weak from exposure and can be a pain in the a$$ to remove cause they break apart. When newer they peel off easier.
Thank god for USCG documentation. Only sticker I have is a June 2009 inspection sticker on the trailer......
Edit - just remembered I do Peel off on my jet ski
In NH, the stickers are a pain the a$$ to get off. They are designed to break into small pieces and the glue $ucks .Sticker removal could easily take an hour or so to do it right. So, I came up with a solution. I went to my local sign company and had them cut some clear vinyl pieces just larger than the stickers themselves. I think 10 of them cost me less then $5.00. I put the vinyl down first and then apply the state sticker over that. In the fall, at end of season, I just grab the vinyl and peel off. It is now a 2 minute job.
I'm really surprised this is even a topic. If I had a 1980s Jon boat maybe I'd just put on on top of the other
I own a sign shop, so stickers and glue removal is everyday life for me. I stack 3-4 years and remove all at once and start fresh. I also make a ton of registration numbers cause there is nothing worse than seeing a 100k plus boat with Walmart mailbox numbers on them. I'm not advertising though, get out there and support your local sign shops.
