Best Single-Engine Boat 30-feet and Under >
Old 11-03-2002, 01:17 PM
  #41
CAP071's Avatar
You should take a good look at Sunsation boats I love mine!
CAP071 is offline
Old 11-04-2002, 09:48 AM
  #42
Charter Member #94
Gordo's Avatar
Default Huh?
Originally posted by 27Fountain
Your asking for allot here, You are going to have to be whippled, to get a under 30 single engine boat to do a reliable 80mph.
Whippled? Why?
Clay,
You've seen a lot of nice boats suggested here. Some better than others, soome faster than others.
At the risk of disagreeing with 27Fountain and Bosco, I have a 25' Active Thunder in full recreational trim, sleeps two, (I've slept in it alot myself), and has run over 81MPH with a Butt Stock Mercury HP500 and Bravo-I drive.
Any questions?
Abby-someone
Gordo is offline
Old 11-04-2002, 10:04 AM
  #43
26scarab's Avatar
Gordo,
Not that I'm doubting the fact that your boat runs 81 with a stock HP500 but what exactly is "full recreational trim" ?
A good friend of mine has a 97 AT Tantrum with a 540 (625hp)in it and that boat only runs 81. Why the big difference ? I will have to admit that his boat is the best riding 24-28ft boat I've ever been in.
26scarab is offline
Old 11-04-2002, 10:30 AM
  #44
Charter Member #94
Gordo's Avatar
26Scarab,
Fair question.
Mine has the usual V berth with opposing setee's, but does not have the small sink/cabinet that I think comes in most other recreational 25 Tantrums. The biggest differences are probably weight, (mine is a race layup, stronger/lighter), and slightly higher X dimension. Other than that, just fine tuning stuff.
Abby-someone
Gordo is offline
Old 11-04-2002, 10:56 AM
  #45
wilerty
Clay:
Although I am partial to the 280 Velocity, if softness of ride and room are the deciding factor you could also look at a Baja 29 Outlaw with a large single. With a Whippled 500EFI you might get 75mph+. It has a huge interior and cockpit for a 29' boat.
Old 11-04-2002, 11:50 AM
  #46
Registered User
BAJA WILL's Avatar
Gordo,
I am not familiar with the 25 AT, 500HP set up. Also maybe I should clarify, I consider a reliable speed, what the boat can do full of gas and normal load of people. I can radar 75, but not with 5 people a full of gas. Maybe your boat can again I am not familiar with that set up. I am curious what prop are you spinning to get 81mph on a 500?
Will
BAJA WILL is offline
Old 11-04-2002, 12:01 PM
  #47
Steamin Rice's Avatar
Clay,
I don't think that you need to get a cruiser to have a good sized cabin. Our boat has a large v-berth in the cabin. I am about 6 feet tall and I can fully stretch out when sleeping in the boat without having my feet hang over the end of the v-berth. My wife is about 5'2" and she can stand up inside the cabin of our boat. Our boat is a true 29' long (no integrated swimstep) with a 102" beam.
There are a lot of great boats out there, and you will know when you find the one that is right for you....Have fun shopping!!
Steamin Rice is offline
Old 11-04-2002, 12:09 PM
  #48
Charter Member #94
Gordo's Avatar
Just before the LOTO Shootout, we were doing some prop testing with approx. 1/2 tank fuel and two people in the boat, high humidity, 98* air temp and 83* water temp. A stock 25p Hydromotive 4 blade would run right at 76.5 mph. That same prop ran a radar 78 with just me and 1/4 fuel on the Missouri river. The best top speeds and cruise rpm's were with a lab finished 28p Bravo 4 blade.
Abby-someone
Gordo is offline
Old 11-04-2002, 12:19 PM
  #49
26scarab's Avatar
Originally posted by Gordo
26Scarab,
So how fast would a "production" model Tantrum run with a HP500 ?
26scarab is offline
Old 11-04-2002, 12:25 PM
  #50
Lee
Lee's Avatar
Hey Mike did you check to see if a spark plug wire or two fell off ?
because someting sure is wrong with your boat to cause it to go that slow. Simply compare it to a 29' Fountain F1 race boat with a stock HP500 and they are runnin 89+MPH all day long.
Lee is offline
Quick Reply: Best Single-Engine Boat 30-feet and Under
