Best Hatch lift ??????
Old 11-03-2002, 11:58 PM
Charter Member #232
Audiofn's Avatar
Question Best Hatch lift ??????
I am looking for a electric hatch lift. So far my favorite is the Gaffrig. Seems to be plenty strong BUT it is SO SLOW at only 14mm per Second. That is only about a half inch per second so it will take almost 48 seconds to open the hatch up. Seem slow to me. Bennet has one that I am guessing is faster but still waiting for the spec. The problem with the Bennet is that if the pump dies you will NOT be able to easily lift the hatch. The Gaffrig has a build in slider to allow for this. Does anyone know of a better solution for this?
Jon
Put your best foot forward!
Audiofn is offline
Old 11-04-2002, 02:20 AM
timewarp's Avatar
I don't know about a fast ram type of lift but the fastest hatch opening I have seen was on a Howard with the Dana Marine Hydraulic hinges, the hatch came up so fast that when it stopped it looked like it was going to keep on going. They are pretty spendy as they use a hydraulic pump and a ram in each hinge.
Might be a little overkill.
timewarp is offline
Old 11-04-2002, 08:09 AM
Charter Member #232
Audiofn's Avatar
Those will not work for me unfortunatly. I have exhaust in the way on the sides. So I have to go with a center post style at the front of the boat. I was hopeing to put something together like the Cigs have (use a standard Alpha trim ram) but that will not fit btwn the engines. I may even have to move the Power Steering over to the port engine to get it all to work.
Jon
Audiofn is offline
Old 11-04-2002, 09:56 AM
Mike J
Jon, I will send some photos
of rams I have used, Simple and
come in differnt Lengths.
I will also send fotos of a
hinge setup that I did that
lifts stright 4in then folds/
Lifts to clear transom.
Mike J.
Old 11-04-2002, 11:32 AM
Forum Regulator
Sydwayz's Avatar
Received 1,288 Likes on 567 Posts
Give Offshore Performance a call at 410.827.0200. Ask for John in service, who is Pwrbt 33 from OSO. He can spec the ones they use for Sonic. I have twin lifts on mine, and they are slow, but they have a dual sleeve, so if the batteries are dead, you can still just lift up the hatch, and the cylinders extent freely. Can't beat it. I think CheckmateF1 spec'd this from John early this year, and it was around $300 apiece, turnkey.
Check out this thread for pics:
http://www.offshoreonly.com/forum/sh...highlight=2003
Sydwayz is offline
Old 11-04-2002, 03:18 PM
Charter Member #232
Audiofn's Avatar
Thanks guys I look forward to the pictures Mike
Hey MikeJ I will be in Cali over Thanksgiving. Lets try and hook up again. I will be heading for a Yardhouse run the Friday just after Thanksgiving.
Jon
Audiofn is offline
Ryan8886
Sunsation
4
01-31-2008 11:15 PM
high cotton
09-14-2007 10:33 AM
thunderusone
Cigarette
7
11-28-2006 03:58 PM
nordic95
Fountain
2
05-22-2006 12:36 PM
Lynn-X
Baja
4
04-11-2005 09:42 PM
Quick Reply: Best Hatch lift ??????
