Temporary Cradle for Cat on lift
I am planning on taking our 28 Skater from LOTO to Florida next winter and I have been exploring storage options for it. A buddy of mine (6 blocks away) has an empty lift that will lift it, but it is set up for a V. I believe that I would be able to fabricate a "rack" out of wood (to support it in the center like the trailer), or I could add wide bunks for the sponsons to sit on. Has anybody done anything like this? I feel pretty good about my skills to engineer/build something once I determine which way to go. Thanks in advance for any ideas.
Received 1,286 Likes
Interesting, I have the same need but haven’t had time to think about it enough.
I keep a world cat fishing boat on the lift but would like to put a v hull on it for part of the year.
I’m hoping to come up with something sorta easy to change back and forth.
Also have to keep the bunks as low as possible to still be able to get of the lift at low tide.
I know a railway carriage with a Skater that has the same exact construction/dimension as the trailer with extra clearance added to make it easier getting in the boat from an existing platform - boat always goes on and floats off perfectly but they did add bow stops at the front of the tunnel to ensure the boat is far enough on the lift
I did this setup when I had my F26 DCB. This is on a 10k Sunstream float lift, but would work on any lift. I bolted on an additional set of bunks so there was twice the surface area supporting the sponsons.
![](https://cimg2.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_7977_b133e4d4110f2b8d926afa16adb662e9f43d5d1b.jpg)
![](https://cimg5.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1504/img_7979_f844272a59a0b6823747431bf04d3af1c6da7469.jpg)
36Tango (02-23-2021)
Interesting topic as I will be mod'ing our lift from the 388 to the 32B.... I've been told by a few folks that if Skater's are on a lift or a trailer, that they are to be lifted on the tunnel spray rails......
![](https://cimg6.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/600x450/transom2_93d6ad471b635e80027b89359eeeda92e2830f1a.jpg)
Everything is for sale @ a certain $$
Drive to arrive alive!!!
Tango,
I modified my HydoHoist lift from a "V" configuration to fit my 28 Skater. I have a somewhat crude drawing of what I did. PM me and I'll share it with you.
