What is the REAL story on the offshore that sank in Michigan
That's why I bought a roll of Flex Seal, you never know what can happen. My brother hit a submerged picnic table on a spring run and wiped out both props and bent the prop shafts on his 43 Cruisers. Didn't know what he hit until he looked at the debris field.
Could of.
But IMO, they would of had to lose a whole drive or if not the gimbal bearing is extremely wiped out of it.
If a bellow is ripped to shreds and the shaft is still in the gimbal bearing, bearing is good, nothing else out of place, where could water enter that fast?
Could of.
I've always been told that, if the main bellows lets go completely, you're going to the bottom. Yes/no?
Thanks. Brad.
(937)545-8991
If the shields are still on the gimbal bearing and the drive is in place, I don’t see that letting enough water in if they were towing someone in,
pull the input shaft out and have a 1” hole and that’s another story, I’m thinking maybe an inlet hose or hose off the sea pump failed to take it down that fast
cheech (07-27-2022)
Driver-441
Racer
Not related to this story at all BUT we had a 302 Formula with KAAMA drive sink on our lake years ago. Went down in the same exact fashion and fast. One of the drives had locked up....twisted right off the boat.
Bearing is press fit in gimbal housing. Shaft is in inner race bore, then there is also a seal in gimbal housing in front of gimbal bearing (gets installed before bearing).
So if there is no failure of any of those and the bellow is breached, water being what it is will get in, but to no amount to swamp a boat.
But like Jaaytee said, once that shaft gets out of the bearing then you better have a good bilge pump.
Another scenario is if the bearing is completely wiped out, missing balls and whatnot.
U-joint fails, yoke breaks the hell out of everything, may wipe bearing out, on and on and on.
It just occurred to me being that Scooby Doo is on the front, it clearly is a Mystery Machine.
Many variables, but in a simple case; no.
