Phenomenon
Dear Brad Christy,
Where do you think you read that?? They had over 80hrs in testing. Best top speed of 195, 50mph slower than spirit of Qatar did in one mile. That’s a lot of catching up to do. Cool idea for a billionaire, just not realistic.
Sincerely,
Igetwet
oh and it weighed 35,000lbs
Sincerely,
Igetwet
It's been quite a while back. Who knows? Maybe while testing was yet to really get underway. I hadn't heard anything about it for quite some time, and nothing of any real updates since. Obviously doesn't mean it didn't happen, though.
It does make you wonder, though.... Why not just start with the 50' Mystic that seemed to be the ticket, instead of reinventing the wheel?
Thanks. Brad.
(937)545-8991
The following 2 users liked this post by IGetWet:
hogie roll (11-03-2022), Velocity941 (11-04-2022)
IGetWet,
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
Theres a video interview of the white guy saying they had 4K a side.
It's been years since I read up on it but I think I recall it being designed to break some ocean distance records originally but then decided to add to it the top speed record (maybe visa versa?) which significantly complicated its completion and it had to undergo major refits/ design changes for fueling and safety concerns etc. Maybe I'm wrong on that. Whatever the case is, in my opinion, this boat, failed records or not is THE most absolutely beautiful piece of marine equipment ever created not to mention what Copeland's rich heritage brings to it. The paint and overall design of it are just incredible there is nothing else like it. It just makes my pee-pee hard looking at it!!
AB From Windsor (11-04-2022)
I also thought Phenomenon was to be a rocket / (long) endurance racer but did not know of the intention of an "offshore"/ shoot out boat like the Mystics - two different playgrounds.
Also, as everyone is speculating, I thought one of the issues with the quad turbine set up was props contacting the mating prop at speed... there should be a old thread with input from a guy that knew the boat during development... thread was about the time of Phenomenon was actually sold. There was speculation the new owner was going to just run it as a twin turbine and do away with the quad arrangement..
OLDRAT (11-04-2022)
I did a quick Google and read the history of the variants on the T55. There were a few that topped the 4K SHP mark (There's one in development that is expected to put out 6500 😮
![Wink](/forums/images/smilies/wink.gif)
Thanks Brad.
(937)545-8991
I read that, as well. This may have been where I read there was only one shakedown run, as it was discovered the props were damaging each other, and they didn't think they'd be able to rectify the issue without major reconstruction of the transom. It seems to me the simplest solution would be to lengthen one prop shaft on each side by just enough to clear the interference. I've seen this done on model boats with twins. This could have also led to the short-of-expectations 195MPH top speed, with a lack of sufficient prop blade area to push enough water to overcome the weight of the boat.
This begs the question, though.... Why hasn't anybody done this with a Mystic. We've seen quad engine cats before. There was and MTI (I think) for sale within the last year with four 1200 blower motors (quadrotors, I believe?). We know there's room to do it.
Thanks. Brad.
(937)545-8991
OLDRAT (11-04-2022)
