Torque Engineering V12
#32
https://www.chevrolet.com/performance-parts/crate-engines/big-block/zz-632
ZZ632/1000 DELUXE TECH SPECS
- Part Number: 19432060
- Engine Type: Chevy Tall-Deck Big-Block V-8
- Displacement (cu. in.): 632 cu. in.
- Bore x Stroke (in.): 4.600 x 4.750 in.
- Block: Cast Iron Bowtie with 4-bolt main caps-tall deck
- Crankshaft: Forged 4340 steel
- Connecting Rods: Forged steel H-beam
- Pistons: Forged aluminum 2618 alloy
- Intake Manifold: Aluminum high-rise single-plane
- Throttle Body: 4500-style
- Fuel Injectors: 86-lb/hr
- Camshaft Type: Billet Steel Hydraulic Roller
- Valve Lift (in.): 0.780 intake/0.782 exhaust
- Camshaft Duration (@0.050 in.): 270º intake/287º exhaust
- Cylinder Heads: Aluminum spread-port; 70cc chambers -RS-X design
- Valve Size (in.): 2.450 intake/1.800 exhaust,Titanium (5/16-in stem OD)
- Ignition Type: 58X crank-triggered, coil-near-plug
- Compression Ratio: 12.0:1 (nominal)
- Rocker Arms: Forged aluminum; roller-style
- Rocker Arm Ratio: 1.8:1 (shaft-mount)
- Water Pump: Aluminum
- Oil Pan: Steel 8-quart
- Recommended Fuel: Premium pump (93 octane or higher)
- Maximum Recommended RPM: 7,000
- Balanced: Internal
cheech (12-28-2022)
#33
Oops sorry, I thought I read they were aluminum. Steel makes more sense.
#36
Here’s a more race engine. Near max effort on the standard bbc 4.84 bore space.
https://www.shafiroff.com/chevy-drag-race-engine-pro/632-tunnelram-big-block-drag-race.php
1350hp 632
The following 2 users liked this post by hogie roll:
Smarty (12-28-2022), Twin O/B Sonic (12-28-2022)
#37
the new trend in blown promod is 5.30 bore spacing allowing way oversquare big bore, shorter stroke. the engine is 2 inches longer i believe, it uses all special heads and can easily attain 1000ci with all cnc billet products. i dont think they will stop there
The following 3 users liked this post by boostbros:
The following 2 users liked this post by iliveonanisland:
hogie roll (12-28-2022), Twin O/B Sonic (12-28-2022)
#40
thats some seriously expensive hard parts
