First Dyno Complete
#41
The following 2 users liked this post by SB:
Griff (01-10-2023), PQ290Enticer (01-10-2023)
#42
The following 2 users liked this post by Unlimited jd:
articfriends (06-12-2023), BBYSTWY (01-12-2023)
#43
Edit: i misread.
#44
“To calculate a valve spring rate, subtract the seat pressure from the open pressure, then divide by the lift.”
So, plugging in the provided #’s:
340lb (open) - 155 lbs (seat) = 185lbs
1.92” seat - 1.370” open = .550” lift
185lbs/.550in = 336.4 lbs/in spring rate
Did i do math right ? 336 rate is low. As example The popularly used Isky 8005A is 400lbs/in.
The following 3 users liked this post by SB:
#45
540Fever, Yup. I missed almost 2 full season's working on these engines between cash flow and everything backordered. Now finally done and It seems everyone thinks I have 2 expensive grenades ready to go off at any time. Obviously it would be beyond terrible if they do grenade but I can't chase something based on opinions of people that had no hand in them at all. Ultimately I'm going with the guys that built and dyno'd these engines. Neither see's a problem with the printout's or the way they performed. If you boat on the Grand River or Lake Michigan and see me getting towed in, be sure to wave and tell me you told me so.
Sorry, couldn't help myself
#47
His cam lift is just .550” vs the .610” to .632” or more we typically see on bbc builds. So maybe that makes the open look lower than normal ? Time for some math for a look see.
OR JUST LOOK ON PAC's WEBSITE
Install height = 194lb
Spring rate is 469lb/in (PAC website)
469*.550 = 258lb
258lb + 194lb = 452lbs open
Those are close to the Comp 933's I run.
#48
https://www.racingsprings.com/index....ing-11334.html
469*.550 = 258lb
469*.550 = 258lb
edit in: Okay, from your link PAC-1940.
Rookie (01-10-2023)
#50
I thought someone talked to pac and they said not to use the hot rod series for marine endurance ?
