First Dyno Complete
Old 01-11-2023, 12:08 PM
  #81
I think I'm going to miss the upcoming boating season.....
PQ290Enticer is offline
Old 01-11-2023, 12:21 PM
  #82
Better to be aware of an issue now rather than when it is an obvious and costly problem. If it does cost some time for this season hopefully the pain won't be as bad as it could have been. Now is the time to get the engines right.
stealthfever is offline
The following 3 users liked this post by stealthfever:
dykstra (01-12-2023), PQ290Enticer (01-11-2023), TeamSaris (01-11-2023)
Old 01-11-2023, 12:26 PM
  #83
Knot 4 Me's Avatar
Originally Posted by PQ290Enticer
So to reach my goal of 500hp using the parts I bought, boring the cylinders was not required and because the bores were in good shape I was able to maintain the standard bore so just a hone. The guy said at my level, forged pistons weren't required. Forged are apparently also heavier(?) and again, just not necessary at my hp level. That was the story.
Apologies, thought they were 509's. Still, I would have went forged.
Knot 4 Me is offline
Old 01-11-2023, 12:33 PM
  #84
The dyno sheets say 4.280" which is .030" standard bore.
Obviously that could be anything typed in.
What pistons do you actually have?
Did you buy 4.250" or 4.280" pistons?
cheech is offline
Old 01-11-2023, 12:50 PM
  #85
Might as well go all the way in.
what were the engines originally?
what cranks and rods are in them now?
454 mags had forged pistons in them stock so they downgraded them.
Unlimited jd is offline
Old 01-11-2023, 12:56 PM
  #86
The bore is still stock. I read 4.25. These were NOT the magnum engines so all cast stuff inside.
Old 01-11-2023, 12:59 PM
  #87
I would have a hard time believing that you could take a standard bore block with some hours on it, hone it to clean up the cylinder walls and only have .002 clearance on new std bore pistons. It could happen, but I bet you have more piston to wall clearance than that.
I agree that forged pistons would be better, but I personally have a favorable opinion on KB pistons. I built many claimer engines back in the day for dirt track cars and used KB pistons in them. I never saw a piston failure that wasn't caused by something else, usually by a dropped valve or severe overheating. We ran these things hard, 7200+ rpm, lap after lap, night after night and sometimes got them very hot. I do know from experience that detonation or too small of a top ring gap will destroy them in very short order. I personally think that if you have enough piston to wall clearance, the top ring has a large enough gap and you don't have detonation, that the KB pistons will be just fine at 500hp. We made way more hp than that with them in small blocks.
snapmorgan is offline
articfriends (06-12-2023)
Old 01-11-2023, 01:19 PM
  #88
KB pistons are junk for marine use,maybe will last totally stock 330 HP engine ,cast I think are better in that case. Ask me why I know this ,fell for the argument over cast pistons once ,never again,also look at casting shift in KB pistons ,one skirt is almost twice as thick as other side,good old Mexican quality control.
Ironhorse dave is offline
Old 01-11-2023, 01:34 PM
  #89
Me to, that's why I asked what pistons he actually got.
cheech is offline
Old 01-11-2023, 01:43 PM
  #90
so you have cast cranks and cast rods with 3/8 bolts?
