Water pump to stat housing hose
GLENAMY, I saw your other post and that looks pretty good. Buying and adding the 2 together makes for a nice finished look. Not opposed to it, just want to know that a one piece hose is not available. Did you find a "barbed" fitting for that main hose? I looked at Hardin's site and only see up to 1".
Hardin has the one for the recirculating pump hose, it is not in the catalogue so you need to call and ask it's stainless. The one from the oil cooler I picked up on line and it is brass that one is 1-1/4" I believe. The one from Hardin I am not sure of the size you will need to measure.
Slow day for me.
Google come up with easy solutions also for barbed couplings.
Way cheaper than the Mcmaster and probably Hardin.
Summit link
If you want billet bling.
ICT billet
Summit link
ICT billet
Thanks cheech. I bought a lot of stuff from Summit but for some reason, I always head to Hardin or CP for my boat stuff. I've got a few emails into Merc and If I don't get an answer on the hose, this is what I will be buying. Thanks again for the help and the link.
Do you happen to know if I need to run that bypass hose from the top of the water pump to the intake manifold? I see some with and some without. Maybe it's a "pros and cons" thing? Thanks again.
Fresh water use and I don't have closed cooling.
I did look for the hose part number 32-847677A01 and it shows no longer available. I'm hoping \ thinking they have a replacement?
So Mercury got back to me in an email and also a phone call. I couldn't believe they actually called me for such a small item. Anyway, the hose is "No Longer Available" and as far as they could tell, nobody in the country has one laying around. Thanks to this site I ordered a couple of the couplers and will cut and extend what I have. Thanks to everyone for your input.
crap, wished i had bought spares now
PQ290Enticer (01-28-2023)
