Sporadically bouncing oil pressure guage
Hi so I got an 1986 campbell corsair. Lots of work done and is running well . Engine is a 7.4L Gen V with carb. Tonight I noticed occasionally the oil pressure guage would bounce from its usual reading of 38 psi down to 25 .( I honestly have no idea if the 38 psi is an accurate reading to begin with). It's random moments that it bounces down and back up for a split second. Guage and wiring being 38 years old I'm hoping it's a guage or sensor thing. The oil is always at exactly the same level on the dipstick and clean, engine runs smooth . Any ideas? Any easy way to confirm actual oil.pressure or guage accuracy? Thanks!
I’m having a similar issue, good question.
Put a mechanical gauge on it to see if it still has the issue. There is a port behind the distributor that you can attach the gauge to. You may have a port also on the port side just above the oil pan near the front inline with front main bearing. I know the Gen 6 does, not a 100% on Gen 5.
Lots of defective sensors out there. I’m on my 3rd one in 2 years. First two would jump around erratically, last one acted normal but wouldn’t show more than 40#’s while mechanical showed nearly 80.
![](https://cimg0.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/565x676/img_5948_10a6ed0e26d96076053ad666df216327ae99daf2.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/581x763/img_5947_544c40d8afbb809a7292b2533930459f07a19327.jpeg)
SecondWind (07-05-2024)
I have a small pile of "new" senders I've collected since 2021. And I had one new sender just recently that would do what you were describing. Since covid parts across the board seem to be way less quality.
