B-max Will Be At Chicago & Cleveland
B-MAX REPAIR
LETS START OFF WITH WATER LEAKS SHIFT PROB. ECT.EVERYBODY KNOWS WHEN YOU INVENT SOMETHING OF THIS MAGNITUDE YOUR GOING TO HAVE PROBLEMS.(YOU MUST CRAWL BEFOR YOU CAN WALK).LEAKS,SHIFT PROB. WERE IN THE BEGINNING OF B-MAX. THEY HAVE BEEN TAKEN CARE OF. & SO HAS THE CUSTMER.AS TIME CONTINUES ON, THIS DRIVE WILL ONLY GET BETTER & BETTER.I AM HERE TO ANWSER QUETTIONS,PROBLEMS & CONCERNS.DEAN IS SO BUSY WITH DEVELOPMENT & PROD. HE CANT ALWAYS GET BACK TO YOU AS SOON AS YOU WANT! THAT'S WHY IM HERE. WE HAVE A DRIVE SHOP ALMOST COMPLETE.WE WILL HANDLE ALL CUSTOMERS IN PA,OH,IN.MI,AND IL. FOR YOUR NEEDS & WANTS.WE WILL HANDLE ALL WARRANTY AND SERVICE THAT YOU NEED.I AM EASY TO GET IN TOUCH WITH.216-390-1330 IS MY CAR PHONE. ANY TIME ANY WHERE. AS FAR AS HORSE POWER LOSS.I HAVE LOST SOME ON WILD THING A 37 OUTERLIMITS.I LOST A FEW MPH. BECAUSE OF GEAR RATIO . THE BOAT CAME WITH 1.37 IAM RUNNING 1.30 NOW. AT THIS TIME THIS IS THE ONLY RATIO CLOSE TO A 1.37 THEIR IS. HORSE POWER TO RUN A B-MAX IN COMPARISON AT 5400 AN XR USES 30 HP,A B-MAX USES 37 HP.COST OF B-MAX IS $12,206.00 EACH.1 YEAR WARRANTY.WITH CONDITIONS OF A BOAT WEIGHING LESS THAN 15,000 LBS-LESS THAN 850HP-AND LESS THAN 850 FT LBS OF TORQUE. COME SEE US AT JR MARINE (JAMIE & RON ) IN CHICAGO OR CLEVE. WE WILL HAVE A B-MAX DRIVE & TRANSOM ASSEMBLY IN OUR BOOTH FOR YOU TO SEE FOR YOUR SELF. RON (WILD THING) BENDER. .
![Smilie](/forums/images/smilies/smile.gif)
WILD THING THE WATERLEAKS AND BROKEN PROP SHAFT AND SHIFTING WERE AS LATE AS LAST SUMMER ....
A TALON WITH 675 EIKERTS LOST 4 PROP SHAFTS BUT AS YOU AND I HAVE SAID THE CUSTOMER WAS TAKEN CARE OF ,,ITS JUST SAD THE DEVLOPMENT IS STILL ON GOING YEARS LATER ON BASICLY THE SAME PRODUCT AND THE UNIT IS COSTING CUSTOMERS WEEK-ENDS OF USE AND R&R LABOR ,IT MAY BE ROCKET SCIENCE TO DEAN BUT COME ON ,,I WISH YOU ALL THE LUCK IN THE WORLD,
BUT BOY IS IT NEEDED
IT WILL BE GOOD TO BE ABLE TO TALK WITH SOMEONE ON THIS
P.S. 5 TO 7 MPH LIKE YOU LOST WHAT WE HAVE LOST WITH THE B-MAX ,BUT ONCE FIXED THEY DON'T BREAK
Charter Member #1171
See ya at McCormick place !!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
B-MAX REPAIR
LAST SUMMER'S PROP SHAFT BREAKAGE WAS DO TO THE HEAT TREATER NOT HARDING SHAFTS FAR ENOUGH UP THE SHAFT. I BROAK 4 SHAFTS MY SELF,AND IM NOT THE ONLY ONE.THE PROBLEM HAS BEEN FIXED.SHAFTS ARE REPLACED AT NO CHARGE. UNFORTUNATILY THIS SHAFT PROB HURT EVERYONE. ONE NOTE TO MAKE IS WHEN YOU BREAK MERCURY PARTS THEIR STILL YOURS TO KEEP AND BUY SOME MORE. ALL PROP SHAFTS ARE NOW BEING X-RAYED AFTER HEAT TREAT TO ENSURE THIS PROBLEM NOT TO HAPPEN AGAIN.MANUFACTURING A UNIT LIKE THIS WILL NEVER HAVE AN END TO SOME TYPE OF BULL**** YOUR NOT COUNTING ON.
B-MAX REPAIR
I ALMOST FORFOT ALL B-MAX & JR PRODUCTS AT CHICAGO SHOW WILL HAVE A 10% DISSCOUNT OFF LIST PRICES. ITEMS MUST BE PURCHASED AT SHOW NOT AFTER JAN 5. WE HAVE INVENTED SOME PRETTY COOL DRIVE TOOLS & REPAIR PARTS. STOP IN AND SEE. RON
Wildthing
Will my big shaft Imco 2" shorties bolt up to a B-max? if so how much can I save by buying your drives without the lowers? My shafts have already been tested..I may be getting closer to buying a pair of B=maxs than I figured..Let me know
eliminator219
eliminator219
B-MAX REPAIR
ELIMINATOR WILL YOU BE AT CHICAGO OR CLEVE SHOW?IF NOT I WILL GET BACK TO YOU TOMORROW ON YOUR OSO EMAIL.YOURE HOUSING WILL BOLT UP BUT VERT. SHAFT WILL NOT WORK. B-MAX HAS THEIR OWN 2" SHORTER HOUSING ON THE MARKET AT THIS TIME.SHAFT PROBLEMS ARE OVER.ALL SHAFTS ARE NOW WORKING JUST FINE RON
WildthingTaz.
I will be at the show in Chicago on opening day and you are one of the main reasons I will be there..If the story is true about your drives not breaking,that you stand behind them but it takes an extra 50 hp to run what I now run,Looks like I will be also looking for some new pulleys to turn my boost up a little.. Keep in mind I will be asking how much your vertical shaft is, I sorta of like the looks of my polished Imco lowers..
eliminator219
eliminator219
