porpoising and chine walking.....what cause's it??
Charter Member#93
My 28 apache porpoised and i was told it was because that they were built with a rocker bottom which makes it faster. When i ran with my 25 three blades it was worse than when i ran the labbed 27's at cruise speed.
I'm not believing the drives are wiggeling urban legend. If so they would do it at 1/4 trim or no trim.
Chine walk comes into play when your trim out, you are riding on the rear most part of your hull, you have so much hull out of the water that the torque of the engine, through the drive, is torqueing the boat till one side of the hull hits the water and starts the effect of the hull going back and hitting the other side, and re[eats itself over and over.
Depending on your prop, if you are chine walking slowly you can counter steer to the chine walk and drive through it.
Prop can help alot, prop and tabs can dp away with most all of the chine walk.
Originally posted by later
Hey Tbone that wouldnt happen to be the teal graphic 38 with blower motors is it, every time i see that boat running it is porpoisin real bad.
later
Dave
later
Dave
the weight distribution is quite common on some of the older straight bottom cigs with big power and big drives. it can be corrected if properly addressed. usually they will lie down as you lean on the throttles, but some get exponentially worse as speed increases = wrong setup! it isn't as noticeable in big water conditions.
dave- yeah, that is it. i think he is running #3's w/ boxes.
chad
Originally posted by bobby daniels
SOME BOATS AT SPEED START LETTING THE DRIVE OR DRIVES START SWAYING BACK AN FORTH WITCH WILL GET WORSE AND WORSE AS YOU GO FASTER,, WITH OUT HYD. STEERING ,SO AD HYD STEERING AND ALOT OF TIMES IT WILL CORRECT THIS CHINE WALKING
388 'S HUSTLERS DO IT DUE TO TO MUCH LIFT BUILT IN THE HULL TO GET IT TO RUN IN THE 80'S ,,,,,,,A WHILE RIDE AFTER 95 EVEN WITH STEERING
ANY play at the drive will cause chine walking. I added external hydraulic steering to my boat after adding 200hp and it still chine walked. Even with the steering I still had slop in the gimbal which I am replacing this winter.
It was different based on what prop I was running. Some props made the boat react different depending on if it was a cleaver style prop or a round ear style.
Originally posted by Wally
Bobby, how can a boat have too much lift? I guess there has to be a compimise but i thought the less wetted surface the better.....to a point ofcourse....
YOUR RIGHT DIXE DOUG I MEANT EXT STEERING AND A TRIPLE 388 HAS SO MUCH WEIGHT IN REAR ITS MOST LIKLY STABLE TO A POINT ,,THANKS
PS ANYTHING AROUND 100 YOUR GOING TO HAVE TO DRIVE WE ALL KNOW THAT IT JUST IF ANYTHING IS LOOSE ON STEERING IT MAKES IT WORSE
several things,but the prop is a big factor at the height of the power curve of the motor ,if the prop is not correct pitch and size it can cause loss of power droping the bow and then the motor trys pulling it back up and does but it can not keep it there so it falls back down causing poporsing,especially at the speed you are talking about midrange,also too much trim,a hook in the bottom of the boat ?just a suggestion of many factors.
