COLD weather coming.....help me out.
Ginger or Mary Ann?
Could also just pull the top of the T-stat housing and fill motor with a mixture of antifreeze, but light on the water. (Just in case there is some water still in the block, it will not dilute even further.) This will also fill the coolers too. Only problem I see is the line from the outdrive to the seawater pump. Like liquid asset mentioned, pull that hose at the pump and drain and reinstall.
I used to do the 100w light bulb trick and it would keep the engine compartment above 32 degrees when is was 22 outside.
I also left the drain plug out so I could look in and see if the light was on.
Hey Chaos, I don't care how cold it is when I see you avitar !!!! It's pretty cold down here, 41 right now and supposed to be in the high 20's by morn..........but it'll warm back up in a couple of days. Go Buc's !!!! Wardey
Budman
10-03-2003 12:26 PM
Jayl13
12-18-2002 02:24 PM
