Opinion on Trailer Manufactures
I am just not a huge fan of steel trailers. More $ initially (50-100% more), more upkeep on the finish, and most of all, twice the towing wieght. Buy the next length alum. over your boat size and you'll be sure to have all the bunk you need for an extra $150-200. You'll then have the ability to move the setup fore and aft to get the balance and tounge wieght just right for you and your rig. They tow well, and a half worn scotch brite pad / dish liquid cleans and shines 'em up nice, very quickly. I have a towmaster alum for my 32' Velocity, marketed as 29/31' and the bunks run from under the dash area to a foot behind the transom, and the bow stanchion is mid-way or more back. I would not hesitate to outfit another boat w/an aluminum I-beam trailer.
![Wink](/forums/images/smilies/wink.gif)
I'll take a Manning over an eagle any day.
They both build a good trailer but I think Manning is
better. And Manning works with you, Eagle has to be
done through a rep.
I don't mind paying top dollar for top work.
I do mind paying extra by quite a few $$$$$ for a name.
With Manning you'll get both for a price you'll be happy
with.
Take your time and do your Home work.
Cougarman
done through a rep.
with.
Cougarman
Just a footnote...90% of the alum. I-beam trailers are built from the same alum. stock and assembled the same way. The only real differences in these trailers is the choice of hardware ( most of them adv. they use stainless) and options that you would choose...mags, brakes, ect. and you'll find they pretty much use all the same vended parts, axles, brakes, couplers, jacks, ect.
I have started making calls based on your suggestions. Hopefully some will be open today. Anyone have a phone number for a jay with Myco or Ameritrail and Manning. Thanks
![Smilie](/forums/images/smilies/smile.gif)
Myco is the best,but if your dropping in salt the Myco will be a big mistake...One stone chip on the paint from the road and your trailer will begin rusting away.They are gorgeous looking though just not practical for salt applications.Keep your suspension torsion (no springs).Loadmaster is right around the corner from me (factory) and that torsion setup with 90wt oil in bearing cap so u can see the bearings with oil splashing all the time is a sweet setup.
Offshores Final Score,
Check out this thread if you would like to see
a Manning Trailer I had on my last boat.
http://www.offshoreonly.com/forums/s...355#post480355
Cougarman
Cougarman
2 different Loadmaster Trailer Companies
Loadmaster that builds aluminum trailers in Florida
http://www.loadmastertrailer.com/
Loadmaster that builds steel trailers in Ohio
http://www.loadmastertrailerco.com/
Cordell
Cordell
