Which boat is faster?? Hypothetical ?
I dont know about other cats but I know that mine likes a little head wind and above all runs its best in water that has a little chop!! Don't like flat water..
eliminator219
eliminator219
Boat B would be faster, run my boat into the wind and then turn around and with the wind and it's faster into the wind, that settles it, proof positive, nothing to hard to figure out here.
I would suppose that the boat would have less lift running with the wind but less aerodynamic drag as well. Given that, if a cat ran with then against the wind, you should be able to determine if increased lift or reduced aerodynamic drag produced the higher speed. Taking it one step (not that steps should effect anything
) further, if you took a boat capable of extremely high speeds, you could do the test at various rpms and attempt to determine where aeorodynamic forces overcome lift potential.
![Smilie](/forums/images/smilies/smile.gif)
Cat & Mice
05-06-2003 12:38 PM
