View Poll Results: Supercharger guys - carb or injected?
Drawthrough carb
![](/forums/images/polls/bar2-l.gif)
![](/forums/images/polls/bar2.gif)
![](/forums/images/polls/bar2-r.gif)
![](https://www.offshoreonly.com/forums/clear.gif)
32
51.61%
Blowthrough carb
![](/forums/images/polls/bar3-l.gif)
![](/forums/images/polls/bar3.gif)
![](/forums/images/polls/bar3-r.gif)
6
9.68%
Drawthrough fuel injection
![](/forums/images/polls/bar4-l.gif)
![](/forums/images/polls/bar4.gif)
![](/forums/images/polls/bar4-r.gif)
7
11.29%
Blowthrough fuel injection
![](/forums/images/polls/bar5-l.gif)
![](/forums/images/polls/bar5.gif)
![](/forums/images/polls/bar5-r.gif)
17
27.42%
Voters: 62. You may not vote on this poll
Supercharger guys - Carb or Injected?
I run an 825 Race Demon on top of an intercooled Whipplecharger. It idles better than the stock carb did. The motor is a Gen 5 454 Magnum. Sometimes I wish I had fuel injection but then I wouldn't be able to tune it like I can with a carb.
Personally I think a draw thru carb setup is the only way to go. It mixes the air/fuel better than a blow thru setup and you don't have the fuel puddling problem. Another advantage of a draw thru carb setup is that the air is actually chilled slightly by the air/fuel mix.
Registered User
carb motors are for sure more forgiving. All they do is take some special care to tune for smooth idle with out fouling. They cost less and will spare you those melted pistons. Otto
Fuel injection all the way, although more expensive, with the right person and computer working on an engine, you can have it start up anywhere, anytime, any circumstance. Better yet, if sophisticated enough, you can make it impossible to hurt an engine other than mechanical failure.
Funny thing, EFI can be done really easy in most cases, if people would fly tuners to there location, boats could be done in minutes, instead of sending ECU's back and forth. Most have success with carbs because they can tune them realitively easy and theres many ways to achieve the same goal. EFI requires sophistacted equipment, knowledgeable tuner and knowledgeable computer. Simple fact is that there are very few with this ability in the "high performance" market when compared to carb tuners. EFI can certainly be overwhelming, MEFI 1 compared to MEFI 3 is huge, then MEFI 3 to MEFI 4, then MEFI to Motorola 555, etc. But its the future! Hell, I can be in my office tuning a boat across the nation, do that with a carb![Big Grin](/forums/images/smilies/biggrin.gif)
I gotta admit though, carbs have been around forever and because of this, parts are cheaper, theres far more common knowledge, etc. so it's going to be more common in this area, but EFI is coming fast and taking over. Many diehards don't mind working on them, but theres far more than get in the boat, don't want to touch anything but the throttles and the women in the boat![Big Grin](/forums/images/smilies/biggrin.gif)
The one thing I would like to say is that there are many, far too many misconeptions regarding fuel injection, it drives me crazy hearing some things, but as someone said, EFI ain't rocket science!
Dustin
Dustin
Whipple Charged has a point!! FI is coming whether you want it or not!! FI set up right is practicly bullet proof. There aren't many people who can set up FI correctly but he is one of them.
Soon, we may be able to get FI with a relatively easy to set up format and we can tune easily FI ourselves. You can get several systems now, but you have to use a laptop and buy the ECU and wiring harness to go with it. Big bucks campared to a carb, but the prices are falling!
It certainly sounds like most guys like carb over EFI. Does any one know if there is a multiport fuel injection system that is manually controled verses electronic as this seems to be the dislike. Personally I like the idea of MPI for power and eficiency I hate the ECM problems.
Dustin
Dustin
Driver-441
![](https://www.offshoreonly.com/forums/images/icons/racer_member_star.gif)
Dustin
Dustin
Blowthrough Nickerson carb. 540 w/ M-4 procharger. Jetted correctly after the 2nd time on the water. On the 3rd season without a change. Have not fouled a plug and is very fuel efficient running on primaries.
