Dodge Cummins Owners this is....
A must. The Blue Chip Diesel FMS is awesome. This is by far the best system I've installed and use in my truck. This may close to a 100 Hp upgrade..
Check it out. www.bluechipdiesel.com
Any Questions e-mail or PM.
If you have a Edge or other it can still be used to give even more HP or TQ.
Doug
Doug
Hey Doug Hows the leg? You working yet.? I saw Chuck is on the board looking for a skater. Have found new motors yet? check with me first to see if I'll be able to use them later. I would not want you to buy something I can't use.
Talk to you later M
Talk to you later M
Funny MAN Mr.Mike,
What should I buy for you and test?
I think Chuck wants to buy an old fixer upper and play with to sell later.???
Leg is ok but still in cast. But I can't go to an airport and fly till the new card comes in to state I have more metal in my leg then an IMPORT car or truck.
Back to thread... This box is AWESOME ...
Mustangs and Cumaro's don't have a chance
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
The Blue Chip is connected to the injection pump. The system does it's own check and in the menu on the box you can tell it to use your chip from mild to wild or none. You can adjust fuel from 0%-63% more fuel.
It also plugs into Map sensor or boost sensor and monitors the boost, comes with fuel pressure reg. that the system also uses to monitor fuel.
It also comes with pyro sender and is all plugged into box so if EGT's get to high it goes into defuel mode till temps drop.
I love the drag race mode it pumps alot off fuel to engine before turbo spool up and pumps out lot's of smoke amd the take off is great when the turbo finally spools up it's like a kick in the ass..
Sydwayz
43
08-12-2005 11:10 AM
berns29scarab
45
03-14-2005 08:54 PM
