quick engine question?
Old 02-13-2003, 03:10 PM
wwwTOPDJcom's Avatar
Question quick engine question?
I have a 99 Yukon 4dr slt its just starting to show signs of hesitation on hard acceleration , this has been getting worse lately ,, I think its Time for a new Fuel filter?
drives normal other than that
wwwTOPDJcom is offline
Old 02-13-2003, 03:25 PM
Any check engine light or codes?
Does it only happen at certain times, ie. hot vs cold engine, only when it rains, etc.
Filter wouldn't hurt. Might be plugs and/or wires too.
Gary
Gary Anderson is offline
Old 02-13-2003, 03:30 PM
Nope wires and plugs were fine 6 months ago no lights
I think its the filter or the electric pump, feels starved
on hard acceleration, if you back off the pedal it starts picking up again, ill throw it on a snap on computer saturaday and check the pressure, miles is about 55k
Old 02-13-2003, 03:31 PM
Dirty injectors?
Old 02-13-2003, 03:33 PM
That should have been:
Dirty injectors? How's idle?
Old 02-13-2003, 03:35 PM
idle is great runs fine , you would not know unless you punched it
to pass, worse in this colder weather, I know colder means more fuel,
Old 02-13-2003, 03:50 PM
Try the filter, it's cheap and easy.
Old 02-13-2003, 03:52 PM
My money's on the the filter.
JaayTeee is offline
Not easy in this cold its like 8 degrees and my buds garage is busy today so no lift
Old 02-13-2003, 04:01 PM
We just started a warming trend here in St Louis. It should be on it's way to you this weekend. You'll still need to wear your mittens though.
Quick Reply: quick engine question?
