View Poll Results: Synthetic oil or not?
Yes I use synthetic oil
301
65.72%
No I do not use synthetic oil
140
30.57%
Hell, I don't even know where the oil cap is
17
3.71%
Voters: 458. You may not vote on this poll
Poll: Synthetic engine oil or no?
#121
Re: Poll: Synthetic engine oil or no?
I also found that 15-50 M1 1 gal was off the shelves in all 3 walmarts around here. Only quarts. How's 10-40 M1 ? They still have it in gal's
#122
Do your homework on oils, you'll find by far the most superior and highest grade of oil for marine use is SWEPCO oils. Have done alot of research as well as talked to several engine builders who now swear by it. Call Sepco and compare their data and oil analysis tests with all other, I have several friends who swore by royal purple who have now changed over and have experienced prolonged friction protection, higher WOT speeds, The oil is as good with 25 hours as it is brand new. Do some research and you'll never use anything else. Wiggler
#123
Different processing configurations involving replacement of dearomatisation, dewaxing and hydrofinishing steps have been developed. Hydrocracking / hydroisomerisation enabled the refineries to produce High Viscosity Index (designated as VHVI or X-HVI) paraffinic base stocks / oils that are comparable in performance to synthetic base fluids. Paraffinic base stocks are preferentially used to formulate most of the world's automotive and industrial lubricants, including engine oils, transmission fluids and gear oils, due to their better oxidation stability, higher viscosity index and lower volatility relative to comparable viscosity grade naphthenic base oils.
http://swepcousa.com/lubesite/products/h306.htm
They are "paraffinic base stock oils" and are considered group III bases and not PAO's or esters. Supposedly, though....American Airlines uses them in their jets..
I would like to see what additives it has..it's an $8.00/qt oil I believe. Why use it over a PAO or ester?
This compnay makes mostly industrial products and is looking at expanding?
We need data and some UAO's of virgin oil.
Not sure.
#124
They are shuffling the line up... You should see the 15w50 back on the shelves soon.
#125
502SCS
Also if you want. I can hook you up with an ExxonMobil distributor in your area. Sometimes we can beat the deals that are at Walmart. I think a few OSOers on here can attest to that. PM me and I can get you a list of where you are at. If you are in Indiana, we can try and take care of you.
#127
Been around a long time and have never heard of them?!?!
Wait, I am only 24... I asked my old man. He worked for Mobil b/f he purchased the business. He's been around for 30 plus years with GPI and Mobil. Never heard of them either.
#128
Most nobody on Bob's site knows about this product that was only available commercially and now offered for automotive use. I don't know a thing about it...I like to know first...how much ZDDP? What detergents? etc...
Maybe sticking with a tried and true product is for you... and you know what they are by now......maybe you like to try new things...up to ya 'all
#129
502SCS
His price on V-Twin is excellent and he is a
trustworthy individual.
Dennis
#130
