View Poll Results: Synthetic oil or not?
Yes I use synthetic oil
301
65.72%
No I do not use synthetic oil
140
30.57%
Hell, I don't even know where the oil cap is
17
3.71%
Voters: 458. You may not vote on this poll
Poll: Synthetic engine oil or no?
[QUOTE]Originally posted by Dock Holiday
[B]Mobile 1
I look at it like this. Mobile brings it right out of the ground to the finished product. I think they understand oil as well if not better than anyone out there.
Hey Dock if it comes out of the ground is it still a syn. oil ???
Only valvoline and some others mix the conv. and syn .oils and call it a blend like durablend ,ect. ?????
[B]Mobile 1
Originally posted by MODVPSST
The man who builds my motors, marine & auto, showed me the inside of two 358 modified motors after one season of racing... one used Mobil 1, the other Castrol , I use Mobil 1 based on what I saw & his advice.... he does NOT recomend synthetic in Blower Motors... I don't know why for certain, but I believe it had to do with bearing wear? I use NAPA racing filters... so far so good!
Hope this helps you understand
have a good week-end
Charter Member #232
I just run the regular stuff. Except for this winter I ussually keep the oil changes frequent and that seems to be fine. I went out for a boat ride then the weather turned on me and I have not been able to pull the boat out since.
Jon
Jon
Put your best foot forward!
I pre-mix in my tanks (outboards) cause I had and oil injection pump go bad once and nuke a motor, I run amsoil synthetic only. it is like $20 per tank in oil as pensoil non syntheic is only like $8, cheep insurance. I have no technical reason other than peice of mind
Charter Member #30
Reckless288,
You support my argument on why to use synthetic. That one time you have a high heat condition in the motor the synthetic will not break down and may have a better chance of saving the motor VS regular oil. Cheap Insurance
I have Steps & Bubbles!
Rough Seas Lie Ahead
I guess the bottom line truly is what makes you feel comfortable thar you've done all you can do to protect your investment is worth the extra money...
Charter Member #1171
ROYAL PURPLE !!!!!!!!!!!! still pull it every 20 -25 hours though
I want to live in a world where a chicken can cross the road and not have its motives questioned.
