Shotgun Muffler Tips???
#32
Originally posted by 32storm
Kaama, in full open position, the shot-gun tips are not any quieter.
![Smilie](/forums/images/smilies/smile.gif)
#33
I have the shotguns and mine are half under water at idle. With the flapper closed and the exhaust exiting thru the bottom of the Shotgun, my exhaust is under water at idle. Sounds like I am through prop except a little more gurgle as the are closer to the surface.
You can also play with the flapper mechanism so they don't open or only open a little even at full throttle. I talked with the manufacturer who said that with a stock 454, there is enough exhaust exiting the holes underneath that you can run full throttle w/o water backing up in the exhaust. I closed em up once when I was taking some family for a ride. You have to get wet to do it but its a nice feature.
#35
![Talking](/forums/images/icons/icon10.gif)
In New York the law requires you to run automatic mufflers. The Shotguns are legal in NY. The Teague mufflers and the Gaffrig units are not because the operator can turn them off or on. Mercury Silent Choice isn't even legal. You should check the laws where you live.
I use the Shotguns on my boat and love them.
![Wink](/forums/images/smilies/wink.gif)
#36
Gone Fishin'
If you ask Drew, he will tell you that the shotguns virtually eliminate any chance of reversion. They keep the pressure inside the tailpipe constant, not allowing for the rearward flow of water. I've been running them for years, and I don't even have internal flaps, but have never had a reversion issue.
'Foul
'Foul
