Paul Pfaff/ Imco 4x4 extreme/Howard
Just got back from Havasu testing my new boat with a Pfaff quad rotor and Imcos new 4x4 sc drive. This is without a doubt the best set up available. The Pfaff injected quad rotor idles at 700 rpm and the shifting on Imcos new drive is as smooth as silk. It is in Howards new 28 Bullet V-hull and with only 6 lbs of boost it ran 106 mph. Anyone considering a repower or new set up needs to seriously take a look at this combo.
Go Fast..
California Hotrod
Sounds like on hell of a machine, What kind of money??How did you come to put that kind of package together? Do you boat on a small lake or will it take some of the snotty water also?
Best of luck with your new ride...
I used to have a Howard,matter of fact, if thy built a twin engine boat, I most likely would still have one!!
eliminator219
eliminator219
cbudge, So that was your motor I saw there in Jan.
As I was drueling over yours,(which I did wipe off),
Paul said this one here is how we are having to build
now, 1200hp that will run on 87 oct. It was the one with
that huge PSI on top.
I know you will have great luck with that motor.
Keep us posted. GEO
Keep us posted. GEO
The cost of the package for a quad rotor and imco 4x4 set up is very reasonable if you buy the package through Pfaff. Call him for a quote on a complete set up turn key. Yes that was my motor at Pfaffs. It really is a great package if you are looking for the best. It is really is not much more cost than Merc 575 SC package with abousolutely no comparsion. not the I think the 575SC is bad you can just get a lot more for your money.
