Drive Showers?
Supercharger..now your talkin
The idea here is to be kinder and more gentle to my new drive. Its the new me, Im not so interested in going fast anymore I just want to see how long I can make it last
Has anyone ever seen a 25 AT with a turbine
![EEK!](/forums/images/smilies/eek.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
![crazy](/forums/images/smilies/gurn.gif)
why even use one. you don't need them. i don't use them racing. with todays sythetic oils they keep the drive cool enough. plus if you have the proper horse power behind the drive there is no problem..
it's all in the wrist.
Treadwell
Treadwell
Treadwell,
I had several hundred hours on my old drive with no shower and know problems until, I let someone go through it and make sure everything was ok. Well a short time later (hrs wise) on flat water, at criusing speed, BOOM the upper gear set goes. When I remove the drive the top retaining nut that is supposed to be torqued to 250+?? lbs is hand tight. The threads arent stipped and it spins freely so I not buying that it was knock out after the gears went. It wasnt ever torqued correctly.
Anyhow I figure since Im getting a brandy new drive, why not?
