Oil Filters Froze Up......help!
Member #9
Been there before. I had luck using the screwdriver through the side of the filter and some of those "choice words" and luckily it came off.
I like the grease instead of oil method, I will try that next time.
Member of the Liquid Jungle
If you have room, a strap wrench might help. I have an old steel one with about a 1" strap, which has never failed me. Good luck....Next weekend i have to change the fluids in both boats......3 motors, 3 transmissions, 1 TRS drive and 2 v drives.....hope i have better luck than you...
I had one where I ended up tearing all the filter off except for the base. I took a piece of 1" angle iron about 9" long, drilled two holes in one side of angle to match two holes in filter base, inserted bolts in holes with nuts on both sides of angle, inserted bolts in holes of filter base and turned. Looked similar to a spanner wrench.
Good luck.
Good luck.
Those Craftsman strap wrenchs really do work and are perfect for this type of thing. I would try this before making a mess pnching holes in the filter. Thats the last resort method. You should have one in the tool box anyway so nows a good time to get a set. You get a small and a large and there fairly inexpensive. Obviously not Coast Guard approved.
Toxic FORMULA
Originally posted by cuda
Makdaddy, that was my first thought too, but I didn't want to say anything.
Keep It Simple Stupid.
Since your doing it from the top of the filter instead of the bottom it's an easy enough mistake
Forum Regulator
Righty-tighty;
Left-loosey.
Left-loosey.
